Hi,
I flashed the bios to 0201, set vcore to 1.53, managed to get 230 fsb at 12x so far , have not tried any higher. Basically I first set the fsb to 220, and the board booted straight from bios. With the old version I was getting the same problem as ryanm, but it seems ok know.
cas 2.5-3-3-8 @ 1T
HT link at 400
I've just run 3dmark 05 and managed to get over 15,000 marks. CPU at 2760 mhz on air, that's not bad.
I have still to check if the graphics are ok in games at these settings, since I have flashed bios I have had no graphics corruption at stock cpu speeds, I'll check @ 2760 to see how well it works...........
Regards
Raja
cas 2.5-3-3-8 @ 1T
HT link at 400
Regards
Raja
but once all the drivers are loaded and windows boots, it may no longer be allocated c:
