Hello: All
I have been reading this thread since it started and I wanted to finally join to tell you my experience on one of these motherboards.
Ok here is my setup:
Opteron 146 CAB2E (stock speed is 2.0ghz) (running at 2.9ghz)
Volts 1.52~1.53
Temp 38~40 Idle
Heatsink Used is a Thermaltake polo
I am also using artic silver 5.
ATI Original 1 x X1900XT (running at stock speeds) 625/725
Driver is 6.3 catalyst.
OCZ Gold Edition PC4000 DDR 500
"2GB KIT" (stock 3-4-4-8, bios reads 3-4-4-7)
Running at DDR 528, 183 divider and timings at 3-4-4-7
Volts 2.70
Creative Sound Blaster Audigy 2 (not ZS)
Driver Used is the Auto Update one from Creatives website.
Seagate 250GB SATA II = HD TACH Burst Rate Score = 238 MB/s
OCZ 520w Powerstream. The lastest version
SLI ready Model
Not Crossfire
![Smile :) :)](/styles/default/xenforo/vbSmilies/Normal/smile.gif)
(why?) It does not matter.
Previous setup was all the same components except the mobo was a
DFI SLI-DR.
I purchased this motherboard about a week ago.
Bios Rev 0201
Mobo REV 1.03G
First off let me state that with my DFI SLI-DR mobo I was able to run at 2950 mhz DDR 536 prime95 stable for at least 8 hours before I shut it down....no it did not error. i shut if off. 8-10 hours no errors is good for me.
Now the DF SLI-DR was and still is a Awesome overclocker. I did how ever have to Flah its bios to one made by Tony from OCZ the 704-BTA something like that in order to run 10 x 295 at a 180 divder and of course a 3x setting for the HT.
Ok now as for this motherboard (Asus A8R32-MVP) I was only able to do "out of the box" 2.8ghz stable for at least 8 hours running prime95 on bios 0201. This was impressive and similar to the DFI SLI-DR out of the box Bios.
Let me also state I don't have any issues with sound, Lagging in games or power issues, as a matter of fact the MOBO rocks.
Now I just recently flashed the Bios to the 0311 and i now able to do 2.9ghz 10 x 290, DDR at 528, Timings 3-4-4-7, divider 183, HT setting is 600 = 3x setting. I ran prime95 for 11 hours then shut it down.
I have not tried to equal my DFI overclock yet, but it is only 50mhz higher on the CPU and about 10 mhz higher on the memory. The timings were at 3-4-4-6 on the DFI mobo.
I have to say that this ASUS mobo rocks and Asus definately has made a TOP contender for the Crossfire overclocker of the year.
Games I play:
BF2
Fear
HL2
Counter Strike
Counter Strike (source)
Swat 4
and many others.
If anyone needs to ask me anything then please do so.
I hope my settings help others out and system build.
