Look at all the screws make sure there in the center on the holes and not touching anything on the board, (assume the standoffs were in installed) try with on board gpu, remove the 460.
Make sure it's on and connected, perhaps try another cmos reset with all power off.
Ive got the 8 pin and 24 pin in, i will refer to manual incase any of the power things are wrong, and i have a PCI E plugged into the GTX and one that i got from the box which also powers the fans, im assuming PCI E is the correct plug for it?
