I didn't ignore that advice? At least, I didn't mean to? Please read:
I checked further after reading the first post he screenshotted, and since then I have had the fuel tank and prop shaft out as well as all the heatshields, and I have stripped off the underseal, ground back a few bits of surface rust that were starting, and sprayed it all with schutz before putting it back together, including coating the new petrol tank in schutz.
I have also removed the front and rear carpeting, entire boot interior, all interior plastic trims, including pulling the dash out. Outside the car I have removed all the arch liners, the sill covers, and other plastic panels.
I found a small patch of rot on the floor pan which I had not seen before which has been cut out, welded, ground back, seam sealered, painted, and undersealed.
The rot has been inspected inside and out by someone experienced with these kinds of repairs.
It won't be left with "bits hanging off of it" for days on end. It will be done a bit at a time, but its not going to be left outside in the rain with gaping holes in it. In instances where something is chopped out, such as a sill, it will be chopped out and have the new one let in, in the same day. As I said earlier, there are only a couple of bits of welding to be done to cavities which are not accessible from both sides - The sills. These will be done first.
I haven't really been obsessing over cosmetics, I bought a new interior and some new wheels because they came up for sale at a good price and solved two problems at once. Since then, sure I have spent money on other bits and bobs like an OBC, map light mirror etc, but none of that has been fitted yet, its just sitting there waiting, and was only bought because it was a good price. The full OBC kit was £150. They regularly sell for £250+now. The map light mirror was £70, they regularly sell for £120+.
I did also spend a lot of time on the DA polishing etc, but that was just to "polish the turd" so I could participate in the end-of-season car shows, which I did, and I don't regret because I had a great time.
I know I'm not perfect and I don't always listen, but I think this is being exaggerated just a little... I get on the defense sometimes because I don't like what I'm hearing, but I do at least look into it afterwards... Its a character flaw.
So is the main complaint now the time of year I've picked (not intentionally) to do this? Because if so it can potentially wait until warmer days in spring but I really wanted to just get it done...
