I could do that but its not ideal on a car which still has an engine and fluids and everything in it, its more for shells.
As for the line/step, just do without it.. Youll waste hours of your life and it will never look right. Filler it smooth
Looks decent, well done.. Well done on taking pictures that is
Haha thanks...
I was also doing some grinding, drilling, cutting, disassembly, stripping underseal and seam sealer, moving wires out of the way of the heat, passing tools, and dabbing out fires. And will also be applying seam sealer, filling, sanding, and painting!
Just I thought I'd better leave the fitment and welding to the professional.
This car is so ******* cool
So you've done most of it and then paid someone to weld it up? Can't argue with that. Although, welding is the best part. The rest is just annoying!
That's a lot of rust , did you kick the floor and your leg went through it?
