thats the plan.![]()
I'm sure they will. Otherwise no bodyshop would ever spray old cars. Most of them have filler in them somewhere. Unless you're asking if I will be taking it to a bodyshop like this having just filled it myself? In which case no I'm not doing that, and I can understand why they wouldn't want to.
I'm painting these bits with cans for now but it will probably go for a re-spray somewhen in the fairly distant future...
Most body shops will "deffo" not take your average respray job back to bare metal.yea a bodyshop will deffo take it back to bare metal, they'll also rub down your filler to get it perfect, unfortunately they'll charge you quite a lot for this..............the advantage of the spray can now is, it'll protect the car until it gets sprayed.......against rust !
you're deffo doing the right thing with the rattle cans..........i found it really hard to hide filler, i always used to see mounds and hills, even when i thought it was dead flat.
whether or not the rust will come back on the underside of the car is hard to tell, because it deffo came back on the Ford Cortinas, usually within 10 months, even if you're really careful, back then a respray only cost 250 quid..............amazing isn't it
they're not doing their job properly then, the bodyshop i deal with takes it back to bare metal, the car is totally stripped...........they keep the car for about three weeks
i am indeed talking about mega bucks, one quote was 6k and the other about 7k, this was last year..... the cars in their bodyshop were all totally gutted and stripped back to bare metal...i've no reason to tell lies m8.
yes you can get it done as you say i suppose...esp if it's the same colour
