what i meant how fast is it 1meg etccsmager said:Exactly what it says?
Downstream speed: 5952kbps
Upstream speed: 448kbps
How else can you put it? 5952kbps is high enough for the 5Mbps BRAS profile (after deducting overheads).
wigster said:what i meant how fast is it 1meg etc![]()
tolien said:It makes no odds whether you're using the connection (from the perspective of transferring anything, not of it being in sync) or not.
You've already told us it's 5952Kbps last Friday, and I told you on the same day that that was high enough for the 5Mb BRAS profile.wigster said:where am i looking to see the sync speed router or??
It's the most accurate you're going to get. It may report attenuation and SNR margins with slight inaccuracies, but sync rates have to be spot on.wigster said:i thought that the router was not a accurate thing to checy by
ZenBroadband said:Your exchange is ADSL enabled, and our initial test on your line indicates that your line should be able to have an ADSL broadband service that provides a line rate up to 2Mbps. Our test also indicates that your line should be able to support a potential ADSL Max broadband line rate of 4.5Mbps or greater. The actual ADSL Max line rate supportable will be determined during the first 10 days of use, after which time the highest stable rate possible will be set. If you decide to place an order, a further test will be performed to confirm if your line is suitable for the service you wish to purchase. Thank you for your interest.
eXSBass said:Question:
How do I find out my SNR and contention ratio with NO router?
I only have a crappy Sagem USB ADSL modem for the time being (until I switch).
Cheers![]()
The "official" instructions are:-
1. Click on the Windows ‘Start’ button - this will then present you with the Start Menu.
2. Select ‘Programs’ - you will be presented with the list of programs on your computer, select ‘Sagem F@0st 800-840’ and then from the sub-menu that appears, select ‘DSLMON’.
3. This will bring up a small screen with the DSL status showing ‘transmit’ and ‘receive’ rates.
4. While this screen is visible, on your keyboard hold down the ‘Alt’ key and then press the letter ‘d’.
Current attenuation is shown in the "Attenuation" field, current signal-to-noise is shown in the "Margin" field.
The following information is available:-
~ Basic stats showing speed along with downstream attenuation and margin in top box.
~ Advanced tab with error counters and margin of both upstream and downstream.
~ Bin plot showing bits allocated to each frequency band. You have to press Reload to get the graph and it takes a while to arrive, so be patient
~ SNR plot showing the margin in each frequency band.
(Images kindly provided by Yarwell.)
You may not be able to access the modem stats because the diagnostics software has not been installed.
If this is the case then you will need to re-install the drivers, - to do this follow the instructions below which have kindly been provided by Yarwell.
WWS|Griff said:From Google -
