- 18 Feb 2007
- London
I use this as a conversion tool if it helps.
Very helpful, thanks.
I guess it’s a bit trial and error at first.
so do you people use liners? throw away or silicone?
I don't see how they are better than a microwave with a fan assisted combination oven.
seems mental, like halogen ovens just another item to take up space when you could replace an item you already have and get roughly the same efficiency without losing desktop space
I've found I can use the fan oven temp listed but knock the time down by 10 minutes or so.
Yep, obviously may need a bit of tweaking but it seems to be a good baseline to work from.So let’s say a product states fan oven at 190c and 25mins, in your fryer you go 190c and 10mins according to chart?
I think this might be the one @montymint gotHas anyone got the Cosori 4.7 litre version?
Wondering if it’s newer than the 5.5 version, as it’s the same price.
No worries, I got the Ninja dual zone in the end.I think this might be the one @montymint got
I knew a guy that shoe-horned a 2.9 litre plant from the Granada Cosori into a Capri years ago but I wasn't aware they made a 4.7 litre version...Has anyone got the Cosori 4.7 litre version?
Ninja dual zone af300uk
Should I preheat? If so at what temp and how long?
Seems like it’s a good idea to preheat reading around.
Doesn't it automatically pre-heat first? My Ninja does but diff model.
Don't need to preheat as it heats up ridiculously fast. AF400 owner here.Ninja dual zone af300uk
Doesn’t have a preheat button.
I will perhaps preheat for 3minutes.
Going to do something easy, one of them part baked baguettes.
I went to my local Aldi at opening to buy one of those air fryers but none in stock
Can you buy anything else < £100 thats actually decent and comparable? Would only be me using it (I know very little about them fyi)
Cosori 3.5L for £79 on Amazon or £99 for the 5.5L version.I went to my local Aldi at opening to buy one of those air fryers but none in stock
