merlin said:You was or wasn't?
Wasn't
Yeah lift of oversteer of death for the lose.
cymatty said:Wasn't![]()
Yeah lift of oversteer of death for the lose.![]()
ScoobyDoo69 said:being an R reg was it phase 1? i cant remember?
merlin said:This was at a time after my brother had already put the Rallye into a hedge with Lift off. Once you experience the famed Rallye lift off oversteer it makes you nervous just getting out of bed in the morning.
GT3 said:I quite enjoy how the back end slides out on command and with a little flick of the wheel and a bit of gas it pulls straight again. Granted it can catch you out if you haven't driven one before but when you get used to it you have a face like this![]()
merlin said:Yeah dude, try that on an off camber road and see where it gets you.
GT3 said:Know the limits of your car and all that...
merlin said:You have to find the limits of your car to know where they are.
And when the difference between facing forwards and facing backwards is 0.1 of a mph.....
s-man said:Incidentally, not wishing to nit-pick since these things are far from an exact science but, (according to Parkers), the Xantia VSX has around 123bhp - The Activa was the then flagship version with 150bhp.
My own personal performance benchmark has always been that a car can be classed as 'not slow' if it has a sub 10 second 0-60 time...which the Sport does.
ScoobyDoo69 said:you guys really are doubters of how capable a sport is arent you?
i believe it was Johnfelstead who in his sport would be tormenting turbos around a track.
its not THAT slow a car.![]()
andi said:And he owned both, not just read about them in a magazine![]()
[TW]Fox said:Not true. Xantia VSX had a 150bhp 2.0 16v engine. Xantia Activa had a 150bhp 2.0 8v light pressure turbo engine, and is thus not comparable as it is forced induction.
[TW]Fox said:But the Sport is 4wd. How does this help? Well, it gives it excellent grip off the line and helps it to post a 0-60 time which gives a false impression of its actual performance.
[TW]Fox said:If we were to compare 30-70 times or 0-100 times for the above cars, you'd see my point. It'll hit 60 in a similar time becuase it's a fair margin ahead by 30mph due to the 4WD, and it'll reach 60 in 2nd gear. The Mondeo, for example, as well as the Xantia, will require a 2nd gear change into 3rd before you get 60, yet it still does in less time than the Sport and without the advantage of 4wd traction off the line..
s-man said:Point taken regarding forced induction but the VSX didn't have the power you're quoting... at least not according to parkers it didn't. Aaaanyway..
You see this is where I feel your lack of familiarity with the car lets you down. Having owned 2 Imprezas one thing you appreciate very quickly is the difference 4wd makes when it's wet and you're driving on the typical British b road. It honestly is a supremely confidence inspiring car. No wheelspin out of wet junctions. Put it into a corner at the right speed, nail the throttle and grip and go. Much less evidence of aquaplaning through the steering and overall much less drama than most fwd or rwd cars. Thats where its strength lies imho
[TW]Fox said:I don't disagree the Sport is fun to drive but that doesnt stop it having a woeful amount of power for a 2 litre engine.
#Chri5# said:Just before the lift-off oversteer hurls you through a hedge backwards![]()
