Not a problemYeah, can you match your quote to my edit please, i realised people who aren't fanatics also wear similar headdress![]()
To those who own the reference 7800XT, in all honesty what's it like in terms of its cooler, i like the design, i know its warmer and louder than any AIB model, apart from Gigabyte maybe, my question is how loud and how warm? What's the Hotspot temps?
The reference 7800XT is £473.47
It's more to do with the delta between the edge and hotspot temp. Less than 20c is considered fine. They don't start throttling til 110c so I can imagine that temp will be ok even in summer.Is around 80 degrees considered fine?
I've not looked at that page, but £474.47 + VAT (20%) = £568.17
way things are going the whole world be at it.
get those gpu orders in before it all kicks off![]()
It says 92 degrees C on Techpowerup's review:
AMD Radeon RX 7800 XT Review
With the Radeon RX 7800 XT, AMD is going after the GeForce RTX 4070. Our review confirms that AMD has achieved performance parity in rasterization and is pretty close in ray tracing, at a much better price point, and they are giving you 16 GB VRAM, instead of just 12 GB.www.techpowerup.com
With higher average GPU temps as well.
Wonder if that's correct?
Even higher than I thought. Higher RPM on the fans as well.
My brother opted for the Hellhound, partly due to significantly lower hotspot temp.
I've seen the Merc 319s go for £500, I think they'd be a better buy...
7900xtx, due to a batch of vapor chambers not being filled to the right levelWasn't there a bad batch of these or was that the 7900xt where in a certain orientation it would overheat?
Not a problem
Do any of the variants with 2 fans have a reasonable hotspot temp?
Maybe these GPUs should've been 3 fan cards only.
It’s a bit late. Sorry been away for a few weeks on work. Did you get a MBA 7800xt in the end? I can say max hotspot even when overclocked to 2900mhz core and 2600mhz vram and undervolted to 1040mv is around 81C tops. The fans are a tiny bit loud on load but honestly in my case I have 10 fans so I struggle to hear the card tbh. I really love the MBA looks and tried the Merc and didn’t like the looks or the fact the IO bracket wasn’t screwed into the cooling shroud so was supported only by the display ports so potentially a point of weakness.To those who own the reference 7800XT, in all honesty what's it like in terms of its cooler, i like the design, i know its warmer and louder than any AIB model, apart from Gigabyte maybe, my question is how loud and how warm? What's the Hotspot temps?
Is clock scaling linked to the hotspot or average temp? I wouldn't let that trouble you IMO. My 6800 XT's had a hotspot in the low/mid 90's since I bought it 3 years ago yet it's never throttled as a result. When OCing without an undercoat it hit around 100°c and still didn't blink.i'm just a little worried about the Hotspot temps, i don't want that to be much over 80c, its the Hotspot temps that actually matter and once you're getting to 90c+ you're at the limit
Starts to throttle the clocks at 110c+ (hotspot).Is clock scaling linked to the hotspot or average temp? I wouldn't let that trouble you IMO. My 6800 XT's had a hotspot in the low/mid 90's since I bought it 3 years ago yet it's never throttled as a result. When OCing without an undercoat it hit around 100°c and still didn't blink.
I wouldn’t call it useless, just a bit slower that’s all.Dont forget if you use the the gpu for anything other than gaming then the Amd card is useless compared to nvidia
Yes, but in terms of clocks prior to that, I'm not sure which it's linked to. Guessing average, or does it not work like that?Starts to throttle the clocks at 110c+ (hotspot).
Afaik it goes completely off hotspot, which is why it's so important.Yes, but in terms of clocks prior to that, I'm not sure which it's linked to. Guessing average, or does it not work like that?
