Driver fusion says" can't delete some entries would you like to upgrade to premium?
Nice another program thats free and probably useless.
Did you use the download link i provided? Replace the main exe with the one i provide.
Did you use the download link i provided? Replace the main exe with the one i provide.![]()
Yeah i decided it was time to change from the trusty but boring default. However im now using this blue one. As you're always telling your wife mike good things come in small packages.
http://i.imgur.com/mXwh27W.jpg[IMG]
An alternative
[IMG]http://i.imgur.com/M5SSMLf.jpg[IMG][/QUOTE]
Cheeky. Wife god no! :D
Have you found me that new AB skin yet? :)
Wow!! Driver Fusion needs a health warning. Spyware in the installer so you need to watch carefully so you opt out.
Driver fusion cleaned up a huge amount of space on my C: drive which is great but how can drivers be taking up so much space when I always uninstall the old ones and remove the C:\AMD folder?
was pointed to this thread by a kind soul in the graphics card subforum as I was having difficulty with my MSI 7950 getting the voltage unlocked.
Followed each step exactly as written and it worked a charm.
Nice one LtMatt !!
Although I cannot turn the overdrive facility off in CCC...
Thanks, I have CCC now disabled. MSI afterburner now works.
What would be a good place to start with a Gigabyte Windforce 7970?
Core Clock 1000mhz and Memory 1375mhz.
In CCC earlier on I had 1150mhz and Memory 1550mhz butt when running 3DMark Fire Strike I got a lower score than when it was factory settings, this was based on an unstable overclock I think.
I guess I am just trying to understand what voltage for how much of an overclock.
Use Unigine Heaven to test the core. 3dmark 2011 (not the new one) to test the memory. Do one at a time, focus on core first.
Start at stock and move up in 25mhz segments. If you crash, get a black screen, or a driver stopped responding message bump the voltage two notches, (0.012v) restart your pc then and try again. Keep doing this until you reach your maximum or until you feel happy. (1172 core is a good medium) Run a benchamrk run on heaven to test. Once completed safely run it again and increase the clocks.
Then do the same with the memory but use 3dmark 2011. Once your score gets considerably worse, or your pc freezes and you can't recover, or your screen has weird coloured lines down it you reached the limit of your memory. You can then knock it down 25mhz and leave it there or up the voltage two notches and continue. 1563 is a good medium for memory overclock.
Download Links
http://www.techpowerup.com/downloads/2111/Unigine_Heaven_DX11_Benchmark_3.0.html
http://www.gamershell.com/download_83546.shtml
@ LtMatt
When extending the clocks for crossfire you only need to do it the once as
now it does both cards at the same time.
No more swapping cards and monitors
This may be a win8 benefit
Cheers,
I ran heaven earlier on these settings...
Core 1150mhz and Memory 1550mhz
I got a great score on standard settings.
FPS - 144.2
Scores - 3632
MIN FPS - 64.9
MAX FPS - 255.3
All seemed very stable, however when I ran 3DMark Firestrike my scores were less than before I tried the overclock so which is likely to be right? Both without a voltage bump. Could I go from those settings again and just bump the voltage by 2-3 notches?
Righto!
Seem to be stable on this.
Stock settings =
Core Voltage - 1175
Core Clock - 1000
Memory Clock - 1375
My overclock =
Core Voltage - 1188
Core Clock - 1190
Memory Clock - 1581
Power Limit - +20
I got a score of 3736 in Heaven and 10080 in 3DMark11.
As overclocks go how is that for a 1st ever attempt?
Looks good to me. If needs be you can always go further so long as temps allow.
When i try to run all tests on 3DMark firestrike though it crashes. Core Voltage increase needed?
Max temps hit on this overclock was 63C
What type of crash? The application itself crashes? Probably core yes, but could be memory as well i suppose. I've not experienced the software crashing as a result of a bad overclock yet. Had a few gpu stopped responding crashes which were solved with a voltage bump.
