I used this method in the past adding /xcl to the AB shortcut to allow full unlock
But I found that I had to change User Mode to Kernel Mode to get it to work for me
Tried this myself and it didn't seem to unlock voltage control and my overclocking range is lower than before :\
Something has to be wrong there as voltage control is not unlocked.
I think ive discovered the problem.
Ok try this. I managed to replicate it not working.
Try placing these two files in your windows/sys64 folder, then do the guide. I don't think the clock control patch is needed, but these files are instead. Let me know how it goes and ill update the guide.
http://www.sendspace.com/file/oh85by
sys64? Didn't think such a folder existed, only system32. Can't seem to find one anyway.
Sorry, its called SysWOW64. Maybe its only there if you have 64 bit windows?
If not you can try System32.
Found it now. So just dump them in loose, no need to place them in any specific folder?
Then just try the Afterburner installation again I guess?
I know even in just unlocking Afterburner on later versions of CCC you need 2 .dll files extra I take it these are the ones?
Regards
Yep. I'm convinced this will work, if it doesn't ill buy you a beer and we can reminisce about the good old days. Hopefully borely gives it another bash as well.
Cheers, I'll give it another bash now!
Edit - Or not
Tried it and still no voltage control. Looks like I'll just have to use Trixx again.
The plot thickens. If i remove those files then the /xcl command does not work for me and afterburner won't open till i remove the /xcl.
Just install afterburner on its own and unlock voltage control. You should be able to do that, if you can't then something is wrong.
We really need someone else to try this to get a wider spectrum.
Maybe you do need the clock control patch.
Done both of those things, and no voltage tweak. Just doesn't seem to work for me, going to go back to Trixx as it worked for me.
