Thanks for posting all the pictures, if i'm aiming for around 1200MHz is that classed as a large OC
Should i try overclocking on Auto fan setup first before using a user defined setup?
Ok, im trying not to be annoying here with constant questions but im looking for a 24/7 OC for gaming
Is 1200 on the core to much to be looking for and 1550 on memory?
1172/1563 is what i use for gaming so aim for that. That gives you 150gig texel rate performance and 300gb of memory bandwidth.
Ok, what Voltage are you using (just for reference). Is it safe to have this OC start when my pc starts and be on all the time
ASIC 60.3%
Download gpu-z, run it then right click in the title bar and select read asic.
Is higher or lower better? mines 66%
I had a pair of 6950 twin frozr ii's that i unlocked to 6970's. I managed to run them at 6970 clocks as well. Make sure you only focus on the core/memory one at a time so you can figure out which is causing the problem then add more voltage to either the core or memory as needed.
EDIT
Now i think about it im not sure if you can add voltage to the memory on Cayman cards. Its been a while since i had them.
I just tried 1170/1550 on 1138v and it froze on 26/26.. Damn
Tried to goto 1140v but resets to 1138v (same with lowering it), cannot seem to get it to stick. Tryed everything on the first page also
Is there new files i need?
1150/1500 at 1138v (max temps 67c in Heaven)
I've clocked it right back which seems to have helped. Also turned some of the bells and whistles off in the settings. Unfortunately now I've got a sound bug! Joy. I feel like the universe is telling me that I shouldn't play this game![]()
God damn LtMatt your a genius
Don't be telling him that
