1165/1550 with 1156v
Put voltage and core down to 1150 and see how it goes. Keep temps well below 70c.
Ok, should i use normal auto fan or make a user defined?
I.E
Normal - Decent overclock (profile)?
nice cheers just tested try 1175/1650 20+power
and a very nice boost with tomb raider fps
card never goes over 60c might help also have a 200m case fan for gpu cooling![]()
I will ask for you.
What version of afterburner are you using?
Aww how cute. It is 2.3.1![]()
Nice plenty of room to go further if you need it as well with that temp.
you sure might even be over max on the mem
according to this review of my card these are the clocks they got for stable overclock
http://www.hardocp.com/article/2012...eon_hd_7970_ghz_edition_review/3#.UTdxphzxrOI
1185MHz and the memory to 1590MHz
Used "Performance Extreme - Extreme version of performance with no increase in sound level but better, quicker cooling." kept the temps around 65-66c and passed in heaven, plaed some tera and it happened again so i reset to stock went back in terror and it still happens. So i assume its a driver issue?
Only thing is i can't unlock the voltage limit, i do the /xcl in the after burner but comes up as an error.
