Yeah, as soon a i put 1150v it stuck. No idea why i didn't try this in the first place.. Lol
Nay bother someone had the same issue a page or two back. The voltage will increase in notches of 7 just so you know.
Unigine Heaven & playing some games (1-2hours)
What about this 3Dmark thing? Is that a viable alternative?
Whats a safe temp? under 70c? or under 80c?
Core Voltage (mV) 1156 <-- Had to increase from 1150 for stability in Crysis 3
Power Limit (%) +20
Core Clock (MHz) 1165
Memory Clock (MHz) 1550
Max temp = 70c
Score = 1370
(when i pressed quit on unigine i got a high pitched noise until the program closed)
How do you test a GPU overclocks stability and how long for?
God damn LtMatt your a genius
Don't be telling him that
Question:
I'm going to follow 'the procedure' (as I'm going to refer to the guide in the first post from now on) for the MSI 7950 Twin Frozr Boost I've just ordered, as soon as it arrives.
I was just wondering if anyone knows whether it'd be a good idea to update the cards bios pre- 'the procedure'. Also, you can't just download the bios from MSI you have to use their live updater tool thingy which also handles MSI drivers and afterburner and such but I want to use 'the procedure' not their stupid tool.
Is it possible to get latest MSI 7950 bios for my card version any other way, and is it worth bothering with?
Advice received and gratefully accepted Lt!
Anybody know why voltage isn't unlocking for my 7870 LE? Works fine in Sapphire Trixx![]()
Maybe you should consider an Accelero for your 7950. I know you said you wanted a quiet card, well you'd have a hard time finding a quieter and more efficient gpu cooler than an Accelero. Excluding water of course.![]()
I've had a Twin Frozr before (5770 Hawk) and I was quite happy with the noise levels. It's going to be practically silent compared the the reference 6950 hoover I've currently got anyway!![]()
After playing Tera Online the screen started to flash and pixel-ate.. I cannot find a stable OC at all (ughh)
69c max temp
