There were non-reference 780s on launch, is it supposed to be the same for 290X?
I've been told, informed, that all cards on release are stock.
No idea if or when custom designs arrive.
Yea...would rather it has equal performance to the GTX780 with a lower core clock speed and ask for a lower price, than beating Titan because of higher clock and charge more for the "factory overclock".Can't say i care personally if it beats a titan if it's priced at or below a 780, it just needs to beat or as be as good as the 780? When i look to buy something i compare it with other items in the same price bracket. (obviously it would be good if it was better than titan im just saying).
Ideally they would price it lower and we might get a bit more comeptition price wise from both camps but i doubt it as too many people are willing to pay that amount for a card.
Well it depends what you want it for really.
Pro's are (in my mind)-
Its the fastest card on the planet
It has shed loads of compute power
It looks cool
You get a golden ticket
works well under water
Negatives are (again in my mind)
2x 7950/7970 will offer equal/better perfomance and you can disable crossfire
They operate way to hot.
Overclocking headroom is poor (if thats your thing)
The card feels half finished and of dubious quality
In my experience of owning one the coil whine is attrocious
Unstable compared to a crossfire setup
Negative scaling in many games and your stuck with it because you cant disable the 2nd gpu !
Am I missing something
R9 290X from dodgy review on Heaven 4
My stock Titan on Heaven 4
Absolutely no contest
I know Heaven 4 is not a game but it is a very good measure of raw GPU grunt. For example a HD 7970 will beat a GTX 680 and a HD 7990 will beat a GTX 690.
Just for fun compare the Temp of the R9 290X to my watercooled Titan.![]()
Disagree with a few of your negatives...as some are based on the Silicon Lottery...
Overclocking headroom appears fine in mines to be fair, mem especially.
Way too hot? Well that depends if you think 80C load is too hot, well ventilated case and it's fine, I've tried various cases, one which wasn't well ventilated was 90C load, so you need appropriate environment.
Coil whine can happen with any card, just your bad luck sadly as I have not a bit of coil whine in mines.
Driver wise you can disable crossfireX and run it as one core if you really want to, so crossfire can be disabled, not sure if this was an addition or not.
Unstable? Again I've had not one stability problem running the card...although again could be down to matured drivers etc.
Of course my experience may have been at a different time.
But that's for 1600x900 res though?Am I missing something
Any news on when we will see figures and when it will be in stock ? Getting bored of waiting now ? Lol
I got a strong feeling that 290X isn't as powerful as the Titan in terms of raw grunt, but what's lacking in grunt, they are relying on the memory bandwidth to make up for it. Just my 2 cents.
+1
All that's happened is some rebadged cards lol
The memory bandwidth advantage on the 290X would most likely not be apparent, until using res of 1920 or above, and/or settings such as SuperSampling. I honestly don't think the 290X's higher memory bandwidth would do anyway for Heaven, particular at just 1600 res.
You say you can disable crossfire now ? , i was using the 13.8 beta 2 frame pacing drivers and there was no option there and radeon pro had no option to do it either ? was this option added in later beta drivers because i see no mention in any release notes and nothing about it on any forums, if this had been the case when i had mine i would have kept it as the ability to disable the second gpu was a deal breaker for me.
Not really. Even for 1920 res, there are more and more games becoming more memory intensive plus having the option to use SuperSampling. We dismissed this setting in the pass, simply because previously, cards simply don't have high enough memory bandwidth for it, and performance take too heavy a hit (we are talking about losing 50-55% of the frame rate). But now we have now came a long way from the 192GB/s of the GTX580 and GTX670...the 290X with 512-bit memory bus with 1250MHz on the memory clock can do 320GB/s out of the box (just for reference, a GTX780 need to overclock the memory clock to 1700MHz in order to hit 326GB/s)...and if the overclock on those memory used are not limited, overclocking the memory clock to 1500MHz would result in a memory bandwidth of 384GB/s, which is DOUBLE of what the stock GTX580 and GTX670 could do out of the box just 2-3 years ago.So useless for anyone who is not running 4k / 1600p at the least?
