Wow I just noticed that it needs a 750+ PSU, I was considering getting the 290X but I can't afford to change my 650W Enermax infinity (which is already 6 years old)![]()
ooohhh
Although it is probably fine, i wouldn't trust it. 6 years is a long time for a PSU when you are on the borderline minimum voltage.![]()
lots of people have the card, no complaints from them.
if it was an issue like Nvidia drivers burning your cards or getting a class action suit agasint you then I guess the buyers would be vocal but now?
You are really reaching Boom. Finding faults is one thing but harping on and on about the same thing, cherry picking parts of reviews that support your argument and constantly refering back to the two review sites that are very negative about the 290x is getting very tiresome.
Most of the review sites give the 290x an award despite having high temps and noise. This alone should show how good AMD have done with this card, that even sites with a known Nvidia bias can give it an award.
And if you look at the results, take the Furmark benchmark. There is only 10 degrees between a reference 780 and the 290x in ubermode.
Now take a look a the 480 that you are so fond of mentioning as an example of Nvidia getting slated for high temps. Well, lets take a look at why it was getting slated. It wasn't much faster than the 5870. It was over 20 degrees hotter at loads. The 480 also used over 100watts more power than the 5870, heck it used more power than the 5970, a dual gpu!! It was all these things and still cost around £100 more than the 5870. And you also got to remember that the 480 was on a die shrink as welll.
So you example doesn't really support your argument in anyway. In fact it highlights how durable GPU's are. There are 480's still around today working fine.
The biggest thing you forgot was the 480 was very late and when it did eventually release it was still broken
Having had a 480 until very recently, it was still an epic card at high resolution (1920*1200) and was nowhere near as noisy as people made out. It was hot, but it dealt with it just fine, and I suspect the 290X will be just the same. Hopefully just as epic. If you know how to tweak the cards, then you will benefit massively over those that don't.
It is a shame it's looking so hot, there is no doubt about that. Luckily it performs very well, and clocks well, so in part can be forgiven. If it didn't, then it would be a very different story.
Found it![]()
Where from?! Any hints?
Never mind, found it and ordered one too!! Thanks for the heads up...
dom99,
MartynB85,
You won't be ripping the cooler of yours without voiding the warranty if you were thinking about it, MSi only let oCuk customers rip the cooler off without voiding the warranty.
@Boom, give it a rest eh?
You keep telling us it's banter, no chance, your in trolling territory now, disappointed to say the least.![]()
