- 12 Feb 2014
- Somewhere Only We Know
14nm 6th Time Over: Intel Readies 10-core "Comet Lake" Die to Preempt "Zen 2" AM4
Look like 14nm 10 core CPU in H1 2019 and 10nm in H2 or end of 2019, think I am glad I stick with 8700K.
Only interesting thing is whether AMD will go 12 core Zen 2 to counter this.
What's the point Zen 2 will have 16.
I don't see Ryzen 3000 hitting 16 cores, that eats too much into Threadripper territory. Level off at 12 cores for now, get the internal optimisations up for IPC and memory speed, get Threadripper 3 at a 16-core baseline and then go for 16-core Ryzen 4000.
Since there's still a lot of gum-flapping from AMD's detractors about "throw MOAR corez at it!!!" I'd rather see AMD get Ryzen 3000's actual cores equal or superior to Intels, and then boost the core count just to rub it in everybody's faces.
I don't understand how people start with the premiss of better cores OR more, Ryzen 3000 will be both, better cores and more of them.
That being said, the 14nm I/O chip better be seriously fast because a Ryzen 3000 capped at 8 cores means there's only 1 chiplet in use, and the I/O die and IF link is never going to be as fast as having all the I/O on die.
Unless, of course, all of the perfect 8 core chiplets are staying with Rome and Ryzen 3000 is getting all the defective dies, in which case purely in terms of maximum salvage, Ryzen 3000 could hit 14 cores (if 7-core chipslets don't get used for a lower-end Rome).
I only started with that "premise" because of where Zen started. As of Zen+ there is still a little bit of work to do to surpass Intel's IPC and memory speed support. Everything we saw in Next Horizons indicated that we will see superior IPC with Zen 2, but it's not guaranteed. I'm just saying that until consumer software catches up with core counts, I'd rather see a Ryzen 3000 equipped with 8 or 12 Intel-beating cores just to fully cement their technological dominance. And shut the fanbois up. Then start ramping to core counts again afterwards.
Another one who thinks in binary ^^^^^^ read on...
AMD are pushing Intel into places they don't want to go, driving core counts up and prices down, way down.
Look, the Zen+ core is already as good as Intel's in terms of IPC, Zen 2 will have better IPC, it can't not given what we know about it, even a very conservative estimate is +5%, about the difference between Zen and Zen+, that will put Zen 2 IPC ahead of Intel, clock speed between Zen and Zen+ was 10%, add 10% ontop of Zen+ and you have 4.8Ghz, that's 5% short of Intel's 5Ghz but with 5% higher IPC, this is being very conservative with the estimates, in certain tasks its actually as high as 29%, i think 10 to 15% is a realistic reality.
Its fine, AMD have got this. Both ways![]()
This was discussed in EPYC thread at great length. It seems some people still believe more cores is better, even if those cores are weaker than Intels cores. I agree with you, AMD pushed 8c/16t parts to mainstream, now solidify your dominance with improved cores, to shut up Intels only advantage today: stronger core and gaming performance. Then in couple of years, then more games are coded using DX12/Vulkan and more software starts using more cores, and gets used to Zen design, then push to 16 cores/32threads.
What's the point of 16 cores now, when intel will turn around and still gonna top the gaming charts, because AMD 16 core chip cannot match Intels IPC and clock speeds.
Gaming performance won't sell enough of these chips for Intel.
