Permabanned
- 9 Aug 2008
won't be long and it will be autumn.
I have this exact one. It was a godsend last night for my little ones bedroom. Took it from 28 degrees to 21 pretty quickly.Bit the bullet and bought one.
For the love of God, I hope it works well! Going to set it up this afternoon
https://imgur.com/gallery/6VrLp09
From what you've said, yours isn't an air conditioner but a snake oil 'water filled' cooler.How? That just looks like mine but twice as tall and mine don't work?
One is an air conditioner, the other is a snake oil 'water filled' cooler. You know the first rule of thermodynamics right?I'd like to know the difference, and yes mine is just a fan with a water tank over it.
How is that Ramcor one supposed to work?
Actual air conditioners have venting pipes to the outside, and chuck the heat from your house to the outside world. They normally have some kind of gas (refrigerant) within them to help the heat exchange. Similar principle to how your fridge works.
Edit: 'portable' is a stretch - they can be moved, they are on casters, but they need to be by a window/venting hole to attach the hose to.
Unfortunately, I have crank style casement windows, so it is quite awkward to install. I did buy some separate zip kit from Amazon but haven't set that up yet...looks like a hassle, but tbf I'm willing to try it in this heat.I have this exact one. It was a godsend last night for my little ones bedroom. Took it from 28 degrees to 21 pretty quickly.
We are fortunate enough to have sash windows so the vent kit that came with it works absolutely brilliantly. The only issue is my little one needs pitch black to sleep so I just use it to give a good blast and then turn it off for the night.
wutA couple of years back I bought a random no-name brand aircon from amazon, the one I ordered was meant to be 5000btu, but they sent me a 7500btu on instead, and to be honest yes it is a little loud, but the trade off is.. I'm not sweating like a sweating thing.. it gets a week or two's use every year, never had to empty it out (Fairly sure it uses the moisture as coolant for the pump so it boils off), I'd not want to do without it now. Only cost me about £220 at the time.. no complaining.
