Permabanned
- 15 May 2006
- London
Well thats were i will buy from if its the cheapest£679.09
Import Fees Deposit Included
+ £17.97 Delivery
From USA ,Can't go on that price
+ £17.97 Delivery
Item:
£558.11
Estimated Import Fees Deposit:
£120.98
Total:
£679.09
£679.09
+ £17.97 Delivery
thanks288W
be around £520 sold in the UK, Just got to look at the
https://www.overclockers.co.uk/giga...et-1151-ddr4-e-atx-motherboard-mb-57l-gi.html
Get a good idea![]()
That will be a tight squeeze. Your 8+(?) fans will get a work out - do you plan on modding the compartment subtly i.e. ripping the door off its hinges?aye, no more after 3 ! hoping ITX format can get it on the work top
wants the Dynamic to be hidden in this ...
https://www.ikea.com/gb/en/p/hemnes-desk-white-10402412/
thanks
Well can't be much more over £520 z390 got almost same gear ,just not 4.0, o well time will tell![]()
I would like a new Ryzen system but I do not usually need to X570 mobo, the B450 is usually good enough for me. Presently the 3600 is a large improvement for my secondary gaming computer and a B450 should be OK for that but I want the flexibility of upgrade the cpu to a 4th gem 16 core (possibly the 4950X). Do you think that an MSI B450 Carbon pro would be suitable for a stock 16 core Ryzen?
That's my take - but every leak is showing fan spinning, even at idle although inaudible (unless deliberately activated for demo).Semi passive with GPUs are it reaching a certain temp and it kicks in , and guessing same would apply here.
Again, was hoping/presuming - as i don't install 'suites' as you know.Question is , can you manually change that in bios ?
Yes - fully powered is a no no.And doesn't he above video break NDA ?
bundles please ?
any eta on your coolers and NVMe 4.0 ???
seems new m.2's have gone under the radar if they'll be launched with x570 boards ....
Plec. best buy quick then, who knows what hardware your son will end up with haha
Thanks @GIGA-Man, appreciated - and have you managed to slip an ITX into your backpack yet?NVMe Gen 4 reviews will be live with X570, in regards to the stock and sales it should be the same day, I am chasing to make sure there is stock on sale for that launch day. No extra info on the coolers yet, will update you when I know more.
Yeah, i'm sure they like the web coverage - although in this case not particularly flattering without context.Though surely MSI can't be too happy then I guess no s***s given if they can get away with it and have their board shown off.
The rumour mill was implying 3600MHz+ was a doddle just after computex - 8pack has hinted the same (i think - don't quote me).3600hz - interesting if this was just plug and play / non Samsung B-Die - on a side note
