Clearly, @tamzzy was the cause of that 'climatic' sentence - his name was closest to your inner nerd.
It will only last 4+ years if you’re happy with this Ryzen or the next. Sockets changing next year according to AMD’s roadmap.Yeah, but as a platform change which should last 4+ years I could probably justify it.
Edit - I meant to put extreme in my previous post with regards to the features (passive Chipset etc). That being said, if the active cooling on the chipset is intelligent (IE only runs when needed) then the passive cooling might not even be needed.
oh dear lordClearly, @tamzzy was the cause of that 'climatic' sentence - his name was closest to your inner nerd.
That Auros Extreme is shaping up to be a pretty solid choice. Plenty of headroom, right angle 24Pin ATX, passive chipset cooling and otherwise a pretty solid layout.
That’s what I want. But I’m worried about the price after seeing the price of the extreme. Could be £400+.
Dig deep, £700
Yeah, that's quite significant. If the lower actively cooled chipset boards are either silent or dynamically adjusted then the lower end boards would make sense.
That or plans for the chipset blocks for custom loops!
To be honest, when gaming... The fans wouldn't be heard, or doing data nvme work using PCIe 4.0 to its limits... They ain't going to be in a 'gaming case or living room '
Ekwb will be loving all these fans, nice mobo block with heatpipe to Chipset
@Plec
https://forums.overclockers.co.uk/posts/32826880/
B450 testing..
It's not a case of being audible when gaming really. It's whether the fan runs 24/7 irrespective of load and therefore is audible when not loading the system.
Thanks, Orbi, had only scan read that thread last visit - missed that amongst the grammar lessons being dished out.
Socket change should correspond to when DDR5 comes available to consumers.It will only last 4+ years if you’re happy with this Ryzen or the next. Sockets changing next year according to AMD’s roadmap.
By now you should be wondering how you were able to do anything with that ancient 1080p... including browsing web and this forum.I switched from a 24” 1080 TN to a 27” 1440 IPS a couple of weeks back, and even on my ancient system it’s rejuvenated my gaming. Everything is just so lovely and vibrant to look at. Started to get back into games that I’d lost interest in playing as they just didn’t get me involved on a poor screen like the new one does. It wasn’t cheap, but it was worth every penny imo, and the new build will just allow it to show off in its full glory.
Nah probs bruv , innit time like
Proper stereo headphones and binaural sound is the way to go.@EsaT - i have ~£100 for gaming headphones (no mic needed) - for stealth'ish Arma 3 mod missions (My son is kicking my butt as i use speakers) - is 7.1 the way to go?
True, but most case fans will be louder even at lowest rpm
Will admit, I'd hear it against 14db shadow wings 2 and 18db Silent wing 3 (£15-20) fans
AMD have stated not on Zen 3 but will be on Zen 4 2021, which I've stated few times before .
They will PUSH new tech hard, as it gets users to buy their tech .
Push DDR5 will mean someone will have to upgrade and buy their board , if it's X*70 AMD will profit due to making Chipset in house and board vendors by them for the chips .
AMD has shown what ram speeds they can do with 1:1 and 1:2 ratio but intel allows more and DDR5 is rated faster, lower energy and larger larger Storage .
AMD finally getting some good business sense behind Zen at last ! Though messed up with mid range Navi, should never of been PCIe 4.0 in a mid range card , added to its price - nothing like an Nvidia Titan V pfr power that cokes on PCIe 3.0 x8 bandwidth![]()
That faster memory bus doesn't do much good, if latency doesn't improve.AMD has shown what ram speeds they can do with 1:1 and 1:2 ratio but intel allows more and DDR5 is rated faster, lower energy and larger larger Storage .
@tamzzy
Another ITX preview for you !!
https://www.overclock3d.net/reviews/cpu_mainboard/gigabyte_x570i_auros_pro_wifi_itx_preview/1
