£200-230.Will this be a decent board to get ? Any rumours on price ?
Most likely £220
@tamzzy
Another ITX preview for you !!
https://www.overclock3d.net/reviews/cpu_mainboard/gigabyte_x570i_auros_pro_wifi_itx_preview/1
£200-230.
Most likely £220
It'll be good enough for a 3900x. Lol.Will it be good enough for gaming with 3600x/3700x ? Pretty much a noob on boards so dunno what i should be looking for if its around £200 then it will be on my list. I need a itx so im pretty limited
Yeah me too. Hope it's closer to £200....but I won't hold my breath...They need to give me 20 quid back for the fan that's going straight in the bin.....still holding out for a 199.99 price![]()
Even current trash boards are good enough for a 3600x/3700x.
So in theory it doesnt really matter what the motherboard is like aslong as it can run the cpu ?
i'll think you'll look at the pricing - next to the incoming Super cards pricing - and then being in a reference blower and think... NAH
wondering if higher costs of Navi are due to PCIe 4.0, same as X570 boards. No one put two and two together till it was known path ways for PCIe 4.0 is an expensive business...
2060 super for cheaper then 2070 and matching its performance - think you'll be swayed . also non reference navi cards are a while off i believe - though not sure @GIGA-Man can hint at that ?
@Plec his 4000hit will work in the Pro/Ultra/Master i believe - prob save the cash with 3600 version and push tighter timings with Ryzen Ram Calculator using 3733hz
@GIGA-Man - Does that mean some reviewers will have your/a PICe 4.0 NVMe to test as well ...?
if true, nice ! just the copper colouring![]()
Thanks for the informed and detailed response, @EsaT - can't say I expected anything less. Very interested in the the AKG K702 from reviews - open design and especially as not bass heavy.>*Headphones* - Excellent summation<
Yep, i own a few pairs of quality Sennheiser's - I replace ear covers and headbands - i won't re-appropriate for gaming as they're my music headsets (I'm not an audiophile - but prefer the sound of open design.) - but may give a cheaper set to my son and bin his gaming headset from your reply.If you're feeling lucky about Sennheiser's fancy and mechanically unwise headband design, then HD559 would be little cheaper and is likely quite good.
(had HD595 start rotting after 2½ years, though that used silvery bling bling plastics instead of normal black plastics)
So the X570 I is rumored to be £220 is the upgrade over the B450 I worth the extra £100 ?
Your going from 4x 50amps to 6x 70amps . MOSFETs are top of the line and run cooler as well .
If your looking to slap a 16 core in , job done . Your current one would be fine with 3800x or 3900x with good top down cooler
Then you've got AX WiFi Vs AC , back plate , bios flashing .
The ITX actually works out the better costing board of the lot lol
Thanx for your reply, i currently dont have any board as im intel but im planning on getting a 3600x or a 3700x depending on reviews and im looking at boards the cheapest itx board is rumoured to be £220. Im just struggling to find out what the difference is and is it worth waiting for the 570 or get a b450. Im not upgrading my gpu for a few years so i dont need pci 4 i dont have wifi 6 router so indunno how much that will benefit me and i have no clue on what memory i would needs as im not clued up like most in here and havnt built a pc since 2014
In answer to your earlier question and given this response then i'd say definitely not, save yourself £100. Memory? you can get a good 3000mhz 16gb kit for well under £100, it will go very well with a B450 board and a 3600-3700X, maybe even a 3200mhz kit, certainly no need to go any furtehr than that.
Here's a highly reccomended (everywhere) B450 mobo.
https://www.overclockers.co.uk/msi-...ocket-am4-ddr4-atx-motherboard-mb-33s-ms.html -
Here's something I found elsewher eon the forum that might help you.
https://i.redd.it/jns90zhx3o731.png
Aorus and MSI h itx boards far better VRM at same costs then the AC.
Better PCB and Dimm design as well , hopefully 3600hz would be fine.
X570 itx designed to handle 16 cores
And then you see how the new PBO works , video on the Zen2 thread. More power... More it'll push it's self with good cooling
