Aorus/Gigabyte X570 - Buildzoid Ripple tests with AORUS & ASUS
How long will we be waiting for this build log?
He's probably sleeping, working or killing puppies so i'll tentatively answer this.
Internals should, hopefully, all be with him by the weekend - in theory (we've all been there).
He may not do a full build log if he sticks to his original case - perhaps some basic money shots at the beginning and end to satisfy Orbi's lascivious needs.
However, if he invests in the rvz03 (and it keeps popping up), it will be of considerable interest as it will have the 'difficulty factor' added (always fascinating watching peoples will to live dissolve in-front of you) plus it's an interesting case/design and, no matter which way you spin it, it will have decent components crow-barred into it. All-in-all would make for interesting build log, but...
But, @tamzzy hasn't specifically mentioned doing a build log - that was just me joking with him when talking about his prospective build - but if he gets the case, i would genuinely be interested in his efforts and probably a few others too.
@tamzzy - a diplomatic and considered answer - hope you appreciate it. I really must be ill...
Hehe, 'if' he were to do one - i suspect it will be pretty rapid as he's waited a long time for this.
correct. i'm still undecided about the case :/ the cheapest is obvs just to reuse current case and cooling.
but if i sold my h100i and evga aio, and get the rvz01 + cryorig c1, outlay would be ~£60.
cooling shouldn't be an issue on the rvz03 as it's really a well designed case. better thermals than one might expect with a sff case.
aaarg...i dunno lol
Oh right. I’ve got a Corsair H100i and I can only hear it when it ramps up, and that’s only when doing really intensive stuff like benching and rendering video. When gaming it stays pretty quiet. But that’s probably because the 3900 is so powerful it just chills on around 10% utilisation when gaming.
what sort of temps all you getting? also do you use the aorus smart fan 5 software to control your fans?
Getting about 35 when idle, maxing out at 75-78 at full load. Haven’t done any work with fans at all. I just let it do it’s thing. Pretty quiet all the time though. Like I say, the only thing I hear is the AIO cooler.
That's better than my temps I have a gigabyte elite x570 with a 3700x and I'm getting around 45-50 in idle and I use an aio cooler also while gaming it doesn't seem to be boosting to 4.4ghz the highest I've seen it is 4.275ghz
The Pro has debug led's, better VRM cooling, USB-C, more fan headers, slightly better onboard sound (ALC1220 instead of ALC1200).
Off the top of my head I think the pcb uses 6 layers instead of 4 & the VRM is slightly different too, international rectifier components instead of Infineon's DrMOS.
Thanks Mandroid, Seems about right after looking at different website searches. I think I'll go for the pro the next time it pops up on a deal.
Registered for my steam vouchers the other day but not even had a confirmation email. Is this similar to experience of others?
Same no confirmation and found this t&c on the page "The processing time for this promotion registration may take up to 6 weeks after the end of the campaign."
Any way to increase PPT beyone 88W on a 3700X?
Though Ryzen Master allows me to select values above 88W they don't do anything, and might be going blind, but I can't see anything anything in the BIOS. Everything else is maxed out and this is the only thing that seems to be limiting me.
Perhaps a BIOS limitation(?) as that's the minimum motherboard default for a 65W processor - this was an issue for someone using an x470 too, but must have been on a different forum as can't find the thread.
@orbitalwalsh ^^^
