Aorus Master / Extreme (3080+3090) Thread
You will be 4th position but possibly 3rd thats if the person in 1st position for the xtreme 3080 order has indeed been cancelled by OC as they had multiple 3080's on order.
lucky me i guess it might lower my eta by 4 months :D in all honesty though if I was in the 50+ queue I would have cancelled cause the rate for this particular card has been shameful.
Had a bit of time this afternoon to have a fiddle about with my Gigabyte Aorus RTX 3090 Master and see what it can really do.
Using MSI Afterburner and Heaven Benchmark 4.0, I've been able to do the following;
  • Raise the Power Limit to 105%/Temp Limit to 91°c
  • Increase core clock by +100. Perfectly stable at +100, seems stable up to around+110 to +115, but at +120 it started to lock up and cause issues. Setting it to +100 means the GPU Clock stays at over 1900mhz constantly when running Heaven 4.0. Ignore the fact that HWInfo says GPU Clock maximum is 2085mhz. Only time i've got the card to go over 2000mhz was pushing it at 120+ and it wasn't stable.
  • Increase Memory clock +250. At +250 memory is running now running at 10,000mhz. Raising the Memory speed doesn't appear to have any real impact on performance/FPS, if it does it's exceptionally marginal (less than 1 fps). I've managed to push this as far as +600 so the memory was running at over 10300mhz. Oddly the higher I pushed it the more the GPU clock seemed to dip back into the high 1800mhz. As such, I scaled it back to +250 (10,000mhz) and the GPU clock stays locked in the low 1900mhz.
  • Temp - Max temp I saw whilst doing all of the above was 70°c. Card seems to run exceptionally cool. No doubt the 4 birth cooler doing it's job. I have my card set in OC mode (default), so if your looking for cooler temps than 70°c whilst overclocking than it may be possible.
  • Power Consumption - Nothing above 390w.
Before Tweaking via MSI Afterburner
After Tweaking with MSI Afterburner
Further fiddling.
Core Clock - +110 (any higher causes issues on my machine)
Memory Clock +1000 (not tried any higher, seems perfectly stable here)
3DMark TimeSpy Result - 17889
Clock frequency
2,085 MHz (1,395 MHz)
Average clock frequency
1,891 MHz
Memory clock frequency
1,344 MHz (1,219 MHz)
Average memory clock frequency
1,344 MHz
Average temperature
64 °C
https://www.3dmark.com/3dm/52956778
Further fiddling.
3DMark TimeSpy Results.
What does it do does it make your computer crash i never overclock my graphics cards worried that i might damage them do you need a good power supply? mine is only 750 watts with my 3090.
Doesn't crash the machine, image just blacks out for 2 or 3 seconds and then comes back again. Not stable. Back it off to +110 and it's a stable run every single time.
I've got a Corsair RM850X PSU.
This is so frustrating, seeing every other model get shipped except the 3080 Xtreme. Surely there’s no way OCUK haven’t received stock at all of the flagship card? Some transparency would be nice but they’ve clearly been reserved for prebuilds or been given away to staff/friends
So is it right that Giga-Man (Gigabyte) have said that a low number of 3090 xtremes have been sent to ocuk, but Gibbo (or ocuk staff) have said there have been none delivered and there are not being shipped to them.?
Really? Okay,I think i've definitely missed something along the line. Do we know roughly how many went out?
Or is it best to just wait for this evening for the next update.
the person in 1st position has multiple 3080's on order and so OC has cancelled this and the chap
I was position 1. I was not cancelled. Just had my shipment email today. Guess I'm getting another 3080 Xtreme. :D
The other Xtremes were ordered from a competitor by myself for others. Whoever you talked to on the phone is telling you fibs.
Woah you got yours? I’m in 4th, not had anything yet
Yep. Just shipped.
Looks like I'm the only one who got shipped to, so looking like another 1 card shipped after 3-4 weeks. I personally think they've just shipped it to shut me up so I don't post what gigabyte reps are saying. None the less, I have another card. Nice. :cool:
Yep. Just shipped.
Hahaha ridiculous man.
