Armorsuit up - Lian li P80N watercooled build
About time I joined in with all the watercooling and thought I would share my build with you guys.
Latest (minus sound card)
Before Pics.
Just wasnt enough room to cable manage well was alright until i threw in a fan controller and another gfx card.
The plan is to use a single loop for cpu and eventually graphics upon next gens arrival, so for now a single 280 (140.2) rad will do and ill add in a 120.3 when the time comes.
Spec.
Motherboard: Asus P7P55D-E Deluxe
CPU: Intel Core i5 760
Memory: Corsair Dominator 4GB
GFX: x2 GTX 460 1GB
Case: Lian Li PC-P80N
Cooling.
MagiCool SLIM DUAL 280 MC Radiator DUAL 140MM
OcUK D5 Vario Pump & EK D5 X-Top V2 Value Combo
EK Supreme HF CPU Waterblock - Nickel Plexi
EK Multioption Reservoir X2 250 Advanced
Mayhems Ultra Pure H20 Watercooling Fluid
Mayhems Biocide
EK PSC Compression Fitting 7/16 [16/11mm] - G1/4 - Nickel
XSPC 7/16" ID [16/11mm] High Flex Hose - Clear
Well I have the case and have ordered everything and the watercooling kit should be with me friday along with BF3 so not sure how much ill get done.
This case is huge and has plenty of potential not sure if i should thank OCUK for making me spend £500 over the last 2 days but I suppose I should.
Ill take as many pics as i can during setup
Cpu loop plan.
Ive gone for the slim Rad on the top due to restricted space up there and as i wont be able to fit it against the case ill be running it in a pull setup so the 2 140mm fans will be pulling the hot air out of the top through the "mowhawk".
Progress 1.1.12
As of 27.4.12
Before Pics.
Spec.
GFX: x2 GTX 460 1GB
Cooling.
Mayhems Biocide
Cpu loop plan.
Progress 1.1.12
As of 27.4.12
Count yourself lucky mines gunna take till about 4-5 so I'm raging cause I got up early cause I didn't know when it would come xD
