** ATi X1k/HD 3k series overclocking guide - ATi Tray Tools and ATi Tool + FAQ **
Jimbo Mahoney said:
LOL, our systems are near identical in spec and scores :D
Compare
(I'm on water with an XT though).
Aye, decent scores mate. Puts us in the top spots on ORB at our CPU frequency too. :)
I prefer to think it's skill rather than luck :p
Oh right. Last time I tried it, it found my gpu/mem to be like 103mhz or something odd.. and it caused corruption on screen when moving them :confused:
Thats what i'm now using as well.If you read through this whole thread,you could be using it too ;)
I could'nt get it to work either,but now it is working fine at last :p
Rob
deciding to try OC'ing my sapphire X1900 XT
i load up the CCC and my defaults are 500/600 so im a bit wtf, i thought the default was 625/725 !?
i got the fan set to 100%
just nudged the speeds too 521/621 in ati tool
(ccc wasnt doing anything, i click ok, and it didnt move at all)
gonna use the FFXI benchmark for my tests xDD
Rob
Dammit ok I'll give it ago tomorrow :p
my powercolor x1900xt wont budge past 660 core and 745 memory even with voltage increases.if i raise it any higher it locks up or i get artifacts everywhere.i guess i have a really bad card clocking wise but still a good buy for the money.
just hope i aint doing something wrong clocking wise but i dont think so as even ccc detects at 658/745.
am i to understand that in CCC
current ore/mem clocks are 2d , and request clocks are for 3d ?
if so then my requested clocks are
690/750
at 1.3v
im still going, my fan is at 100%
i havent seen a single artifact, or for that matter a single increase in the benchmark ive been using ( FFXI benchmark 3) and also the video stress test in CSS, should i get 3dmark 05? will i be able to seee a difference at all ?
:edit:
CCC wasnt showing any changes, im now gonna use ati overclocker, and disable ati tool.(used ati tool to change fan speed and volts)
I have exactly the same prob, except I can get 661/785 pretty much sorted :(
Conc
