barney said:One very worrying thing is the temp of the volt regulator. it says its running at 99C!!!!!! this seems insanely high? is this reading right, can it run that high? It seemed to be running high on lower clock settings too. I wont put the core up any higher (infact after i have tested it im going to drop it down and reduce the volts until i find out the operating temperature of this).
Agent WD40 said:Err, 99C does seem a little warm.
barney said:So word of warning to anyone overclocking these. Make sure you have a side mounted fan blowing air over them
How do you get the regs under water?The Asgard said:Or better still have them running under water for total silence
I know, I was being facetious.Concorde Rules said:You dont, you still need a fan for em...
I've seen custom ones, but not a retail, any idea on the make?Jimbo Mahoney said:There is a waterblock specifically for the voltage chips on the X1900 cards.
fornowagain said:I've seen custom ones, but not a retail, any idea on the make?
Concorde Rules said:Yes, your using CCC.
Use ATT and ATi tool, for the love of god!
Rob43 said:Are you starting to feel like your banging your head against a brick wall yet mate
Rob
