Unless it's something like a clio sport or another warm/hot hatch - auto.
I'll add another one as this used to be quite big for Porsches, it's far more difficult (but not impossible) to over rev the engine with an auto. There were quite a few stories of issues due to somebody selecting the wrong gear (say 1st instead of 3rd) and revving the car past its redline.If you look at things objectively [good] autos are better than manuals, because manually changing gears is a bit of an anachronism - something that isn't necessary for 99.9% of use cases. Gear changing is just a construct required to make cars go faster rather than an actual design feature implemented for some other reason. If cars had always been automatic I don't think people would introduce manual gear shifting or at least not in the traditional clutch and gearstick way. The only downsides I can see are:
-Potentially higher cost
-Potentially bigger repair bills (however on the flipside the clutch is less likely to get misused)
-Sometimes means lower fuel economy
-Historical stigma around manual vs auto in the UK and people tuned to the 'involved driving experience' of a manual
Are you referring to your old e39? - assuming you still have it - I remember the debate when you bought it as a manual.I won't even rent a manual anymore let alone buy one. Well except the one I did buy which I regret every time I drive it
A quick unscientific test - just looked on AutoTrader and it's roughly 42% autos, 58% manual. The gap is closing and fast; I think even just a few years ago that split would have been closer to 30/70.
That said, I've just found out the latest incremental Ford Focus update to the Vignale model gets rid of any manual control of the 8-speed auto in it, replacing the manual button with a "Low" function like the gearboxes of old, to switch to lower ratios to aid in engine braking. Very disappointing as I'd already planned to pick up a Vignale to replace my current Focus in a few years.
I tested them on the 440i, but I also can't see me using them. Sport+ is more than capable of handling the shifting for me on a spirited drive. I think I probably drove on the paddles in the S3 less than 10 times in 3.5 years.I never ever use the paddles in my 8 speed auto. There is just barely ever any need.
They might bring back the paddles when they switch back over to the 7 sped DCT.
Is the Focus expected to switch to a DCT? I know the new Focus ST 7-speed is actually a torque convertor auto (it's the 8 speed but with 3rd gear dropped), and the new 7-speed in the Fiesta is a DCT. I'd be expecting the Focus to stay with the slush boxes.
I don't have any knowledge, but I assume they'd want to switch back from the torque converters ASAP as they can then sell them with lower CO2 emissions/better fuel economy. I appreciate they are different cars with different weights etc. but the 125 7 DCT in the fiesta is rated at 129 lowest 134 highest CO2 emission and the focus 8 speed torque converter is 134 lowest 144 highest.
But I guess it might be the Fiesta/Ecosport/Puma use the 7 speed DCT, the Focus the 8 speed and the Kuga uses the Hybrid CVT on petrol or the 8 speed for the diesel.
What happened to the real drivers on ocuk?
Driving a camaro
