THIS!More phases, the better the power delivery for either high number of cores or very high overclocked with voltage or both ! Less chances of CPU speed throttling down .
More layers normally equals more complex engineering to minimise interference in the circuitry.
For gaming and more applications, your not going to see a difference between PCIe 3.0 and 4.0 ssd.
Flagship b550 match mid range x570 for having 3x m.2 slots are slightly cheaper prices so sorted in storage front
I don't have any new info on B550 so I can't give specifics and I don't yet know price points. However, I just wanted to touch on a couple of things mentioned here.
B450 Tomahawk pricing, along with most other circa £100-200 boards has risen due to an increase in component costs...capacitors mainly..along with a weakening of the pound. The more aggressively priced the boards were (generally cheaper boards) the less able the manufacturers were to swallow this price increase themselves.
Unfortunately, you can't just look at the number of phases to judge the likelihood of power delivery limitations. I've seen boards from the same range, same manufacturer and the same number of phases perform considerably differently. The quality of the VRM's along with the cooling will have a big impact. @orbitalwalsh mentioned the current differences, this is a really good way to judge these factors.
PCI-E Gen 4 is a good "tickbox", a great "headline" but in real world performance numbers it's never going to be a deciding factor for me. Currently, you'd have to get your stopwatch out to have any chance of measuring any difference vs gen3. Personally I'd suggest that you look at the number of lanes/slots made available on the boards when making a decision on which to buy. Future expandability has always been a major consideration for me personally.
Also, early word was that the B550 chipset would not support Gen4, this would explain the lack of a chipset fan... so I'm left wondering if something was changed or whether third party controllers are being used. Currently I don't have an answer.
We've had absolutely no word on A520 yet.Where is A520 though
& yes, GODDAMN some of those boards are pretty!
