Personally I'd put your starting numbers up.
You can squat 110kg and bench 60kgs.
Surely you can squat 70-80 for 5 reps? and bench 40 for 5 reps also?
Yes, ego should be left at the door. But it should never be 'easy'.
I think I was being a bit cautious and letting the weight maybe be a bit too low. But I think if the weight goes up every session like its meant to then it wont take long to get up to 70-80 (about two weeks).
As for having my bench that low, sure it was easy as well, but I found my form miles better. Now I am going to try and be a lot more strict on my form and remember how to bench properly. And make sure that carries on as the weight increases.
I went again maybe a bit too light but I can see it becoming pretty hard in the next couple weeks.
), I would definitely keep them under 8 reps though and just add weight! It's a strength routine after all, so 5x5 heavy dips and pullups are the perfect compliment to the barebones program IMO.
