Hi!
There is a P5K-E (WiFi) + Q6600 system that we want to squeeze out a couple of months of usefulness before upgrading, so I'm looking for some hints to overclocking.
Originally I overclocked it to 3 GHz (set FSB to 1333MHz or 333 as it says in the BIOS setting) but changed it back as the stock performance was more than enough back then.
Recently I set the FSB to 333 again (and the RAM to DDR2-667) and it worked OK (no crash), but the temps were strangely high.
On stock clock in idle it was around 60 degrees (according to CoreTemp) and about 85 degrees running Prime95 Small FFT.
But when overclocked, in idle it showed 80 and with Prime95 it went up to 100 and triggered thermal throttling.
So the questions are:
- is the higher temperature normal? Or did I set (or forgot to set) some related BIOS option?
- a set of tested settings for overclocking to 9x333 MHz (and everything else at standard clock: PCI-E, RAM...) would be welcome
- could it be the CPU is less overclockable due to age?
Info:
BIOS version (can flash other): 1102, 19.6.2008
CPU stepping: G0
RAM speed: 800 MHz (4x2GB Transcend JM800QLU)
Regards,
David
PS: I checked the FAQ and it says nothing about posting to older threads. Some forums frown on it. If this is a problem, pleas move my message to an appropriate place.
