yesterday, i was getting more BSOD's and high temps so i lowered the FSB from 389 * 9. As follows:
PASSED - Prime Small - Run for 35 Mins Temps 65/66
[C1E Support] Disabled
[Prime95 - Round Of Checking under AdvOptions] Enable
Ratio CMOS Setting] 9
[FSB Frequency] 379
[FSB STRAP to NB] 333mhz
[PCI-E Frequency] 101
[DRAM Frequency] DDR2 778
[DRAM Command Rate] 2T
[DRAM Timing Controls] 5-5-5-23
[CPU Voltage] 1.3875v
[DRAM Voltage] 2.10
[CPU Voltage Dampener] Enabled
[North Bridge Voltage] 1.55
[FSB Termination Voltage] 1.3
PASSED - Prime Small - Run for 35 Mins Temps 63/65
[FSB Frequency] 379
[CPU Voltage] 1.3750v
[DRAM Voltage] 2.10
FAILED - Prime Small - run 10 Mins Temps 62/63 then BSOD
[FSB Frequency] 379
[CPU Voltage] 1.3625v
[DRAM Voltage] 2.10
I've now gone back to [CPU Voltage] 1.3750v. Is '65' temp too high????
I'm guessing i should lower the FSB even more now as i doubt it'll pass Prime Small Test for 8 + Hours.
I'll keep you posted. A bit disapointed in my OC speed tbh.
[FSB Frequency] 379
[DRAM Voltage] 2.10
[FSB Frequency] 379
[DRAM Voltage] 2.10
[FSB Frequency] 379
[DRAM Voltage] 2.10
