- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Hey guys
Pricing is now even better on the high end Phantek Coolers!
They are a performance monster and a thing of beauty.
Phanteks PH-TC14PE CPU Cooler - Silver (LGA 2011,1155,1156, LGA 1366, LGA775 and AMD AM2/2+/AM3) @ £64.99 inc VAT
nonl2br Phanteks PH-TC14_PE twin tower thermal radiator design uses the latest aerospace technology. By using P.A.T.S to increase cooling performance and C.P.S.C Technology to enhance thermal conductivity, heat will easily dissipate, creating an opportunity for greater overclocking. Combined with Dual Phanteks PH-F140 Premium 140mm Fans, easy-to-install SoliSku mounting kit and PH-NDC thermal compound, Phanteks PH-TC14 with unique colored is setting the new standard of today’s CPU cooling.<br>
<br>
- Intel Socket LGA 2011,1155,1156, LGA 1366, LGA775 and AMD AM2/2+/AM3 (stock backplate required)<br>
- Fan Size: 140x140x25 , Dual Fans included.<br>
- Fan Compatibility: 140x140x25mm x 3 pcs, (120 x 120 x25mm x 3 pcs). (Third fan clips and accessory included).<br>
- Bearing Type: UFB bearing (Updraft Floating Balance bearing)<br>
- Blade Geometry: 9 White colored Blades with MVB (Maelström Vortex Booster) Design<br>
- RPM: 1200 RPM ± 10%<br>
- RPM with Q.S.A: 900 RPM ± 10%<br>
- Max Air Flow: 78.1 CFM<br>
- Max Air Pressure: 1.21<br>
- Acoustical Noise: 19 dBA<br>
- 5 Year Warranty<br>
<CENTER><IMG SRC="http://img256.imageshack.us/img256/6861/awardsjq.jpg" height="150"/>
Was £72.99 Inc. VAT
Only £64.99 inc VAT.
ORDER NOW
Phanteks PH-TC14PE CPU Cooler - Red (LGA 2011,1155,1156, LGA 1366, LGA775 and AMD AM2/2+/AM3) @ £64.99 inc VAT
<br>
Was £72.99 Inc. VAT
ORDER NOW
Phanteks PH-TC14PE CPU Cooler - Blue (LGA 2011,1155,1156, LGA 1366, LGA775 and AMD AM2/2+/AM3) @ £64.99 inc VAT
<br>
Was £72.99 Inc. VAT
ORDER NOW
Phanteks PH-TC14PE CPU Cooler - Orange (LGA 2011,1155,1156, LGA 1366, LGA775 and AMD AM2/2+/AM3) @ £64.99 inc VAT
<br>
Was £72.99 Inc. VAT
ORDER NOW
<br>
Was £72.99 Inc. VAT
ORDER NOW
<br>
Was £72.99 Inc. VAT
ORDER NOW
<br>
Was £72.99 Inc. VAT
ORDER NOW
<br>
Was £72.99 Inc. VAT
ORDER NOW
