Best XMBC Box
Personally, I'd get a fast USB2 stick too.
I use OpenElec, prefered it to Raspbmc. I tested all 3 for a week each.
http://openelec.tv/forum/124-raspberry-pi/65267-the-fastest-pi-ever-working-like-a-dream
I will check that out then.
http://www.amazon.co.uk/Raspberry-P...id=1420794120&sr=8-1&keywords=raspberry+pi+b+
With what the guys said below you would this be enough?
Can I set this up and plug it in the tv and I will be good to go? I will just use the XMBC app on my phone as the remote.
OP, I think you need to do some more reading up on XBMC/Kodi and other supporting technologies.
XBMC is a media player, which plays content from the sources you tell it too. Its how you get this content that is key, and a lot of the methods and sources are not going to be suitable for discussion on this forum.
It is not a case of just installing XBMC, turning it on, and getting all the TV and Movie content you want.
Skeeter, you clearly haven't read the entire thread.
I went to test out Kodi on my laptop for the past two days and have installed many addons.
I am aware of how it works now and that is why I want something like a raspberry pi as it will cost a lot less to run than a laptop
Im expecting my pipo x7 early next week if you hang on Ill do a run down of if its any good for this as I think it will be amazing for this purpose.
What made you choose that?
Runs full windows x86 so can install anything and use windows apps. Cost £65 with a years office 365 sub. Very low power usage as it uses atom baytrails. So much potential for torrenting/ using browsers or as a full pc aswell which many android boxes wont do.
I'm not fussed about using Windows, I love Linux and this will strictly be used as a media device anyway running Kodi and I will hook my NAS to it as long as it doesn't draw too much power.
Raspberry Pi + remote + USB hub + SD card + PSU + WiFi + ...
The Fire TV will be back down to around £60ish again soon. I had a Pi and when you start adding up all the extra cost of a Pi it soon adds up.
40 for the complete pack and 5 for usb. Comes with wireless and has 4 usb ports. As I said earlier, I will be using my smart phone as a remote. You clearly aren't reading this thread at all.
You asked for the best XBMC box.
The Pi works (I have one), but it is lacking in CPU power. It's far from the best.
