BF2 1.5 patch on 1 September
[TW]Fox;14793658 said:
Whats the best download link? I'm on a 10Gb line and cant get more than 346kb/s :(
10Gb wow...:p
Unless you are in fact on a 10Gb line at work or something - still I find that unlikely ;)
Anyway - just thought I'd be pedantic whilst it was you Fox ;)
The patch seems OK to me!
Problem number 1
I couldn't alt tab out of 1.41 now with 1.50 I can but the game wont come back up AGH!!!!!!!!!!!!!!!!!!!!!!!!!!!
EDIT!!!!!!!
Booted game up....game closes! something not right here
EDIT again
Got into game and every so often it freezes for about 5secs ping goes massive. Happend on 2 servers 3rd time it happend I got an error saying PnkbstrB has stopped something like that
Also happening to other players
AA gun has poor lock black hawk is way over powered
Damn :mad: Got the patch downloaded, installed game & got the following error
Program:...Files\EA GAMES\Battlefield2\BF2VoiceSetup.exe
A buffer overrun has been detected which has corrupted the program's
internal state. The program cannot safely continue execution and must
now be terminated.
Continued with install, applied patch & now PC keeps crashing to desktop whilst looking for servers :(
now be terminated.
You could try and reinstall the visual C++ redistributable package.
If this fails try a complete re-install if that fails I aint got a clue.
Tried a full reinstall did same thing again. Also tried running the program from within the game folder after it was installed & i get the same error.
They've epically broken AA support for at the very least most ATI cards :( Me and at least 4 other people I know have to disable it to be able to play normally :(
From http://blogs.battlefield.ea.com/bf2...attlefield-2-update-v1-50-is-almost-here.aspx
It says,
"Server providers around the world will have access to the client file so find your closest host for best download speeds. To install Battlefield 2 Update v1.50 you must have Battlefield 2 updated to version 1.41 or Battlefield 2 Complete Collection from EA Store installed"
So yes a fresh reinstall it seems!, although I'll try to overwrite from 1.5 Beta 3 first and see what happens!
You can also patch straight from 1.5 Beta 3 to 1.5 as if it was an incremental, it only takes about a minute.
Works fine here - got it at 8xAA on my 4870
What drivers and OS? If I enable AA one of three things happen at random with my 4870:
Tabbing out fails miserably but other than that it's OK
The floor completely disappears
It loads into the game fine, you see the actual game with AA for about a second then it crashes to desktop.
I cant believe they didn't lock out the helicoptor gunship seat switch so 1 person can fire the heavy missile. :mad:
