https://youtu.be/bawzisErdqQ?t=367
That's pretty cool, didn't expect it to shift from the 7 series to 5 so soon.
Teslas have had these features for ages and you don't need that massive key either.You didn't?
Even though every single 5 Series has contained tech introduced on the 7 Series released just before it? It's what BMW do every single time - the 7 Series is always the first car of a completely new generation, and then the tech comes out on the subsequent 5 Series![]()
You didn't?
The 5-series of each generation is always effectively a photocopy of the 7 but set to reduce. The tech available in both cars is largely similar and is copied over. The 7 obviously retains a higher standard spec level and has a few exclusive high end options but the fundamentals are always the same.Never really paid attention to either model up until receently.
I was also told that BMW have pulled all support for M car deals so there's no longer any deposit contributions available for them.
I don't know, but it's what I was told. I think they're about to launch the LCI M3 though, so maybe that has an impact on it.I believe that is wrong. Without massive discounts they won't sell any M cars if that's the case...
I think the new key is a bit too big though, can you imagine trying to put that into a pocket if you're not wearing a jacket?
I was offered £4K off a cash purchase but that worked out to less than 7%. A far cry from the nearly 20% that could be negotiated last year!
that M3 looks nice, but that sounds very expensive for a used one.
