Budget?That's a fair point, more about finding a balance than anything else. I'm not particularly desperately looking for one in all honesty but seen a car that perked some interest.
2010 330D n57 touring with under 60k, xenons and some options like high beam assist but it has business nav and weirdly a manual box.
Just having a think about it really, it's still a decent looking car and feels a fair price (albeit tourings in general can be a bit wild). I would much rather an f10 even if it was an early 525d but there just doesn't seem to be any real availability
Viewing a Z4 this weekend, anything in particular to look out for?
Had a new hood motor a couple of years ago and relocated, VANOS and DISA rebuilt and new springs all round 3 years ago, this seems to cover all the most common issues?
Its a 3.0i with the M54 engine
third rear brake lights crack every time you slam the boot down.
if it's cracked your looking at £80ish for a new one with new springs and screws.
the trick is to screw it in loosely too tight and the tension of the springs causes them to crack. so don't screw them in thinking this will make it hold. screw them in lightly to stop them from snapping basically from the tension of the screws/springs
electrical steering fails are common now and they are around £1500-£3000 for a repair depending on where you get it done.
