What about via the bmw-connecteddrive.co.uk site? You'll have to link your car via VIN to your account to be able to do it.
Do this first. Register, add the car, then the rest will work.
If I try and login it tells me I already have a BMW account elsewhere (I do, the My BMW one) and I can't register as it tells me to log in using my existing credentials. I'll get the VIN at lunchtime and try to enter that into My BMW and see if that makes a difference.What about via the bmw-connecteddrive.co.uk site? You'll have to link your car via VIN to your account to be able to do it.
Been looking into E65 7 series as I would like a nice comfy barge. Apart from oil leaks and burning oil on petrol engines and dodgy turbos on diesels, what else do I need to look out for? I've also been told to check for a good service history, specifically oil changes, whilst also checking suspension.
What else am I missing?
Water leaks on the V8s are an engine strip job. PCV can fail and is a pig of a job as it's right at the back of the engine. Hunting while idle is a symptom. Mechatronics issues with the gearbox are fairly common.
Lots of software gremlins that should have all been sorted by now if they car has a full BMW SH.
They are pretty solid cars. I've had two of them (a 2007 730d and a 2006 750i) but was running them when they were still relatively new. Get a post 2005 facelift if you can. It has a much better iDrive system and softened styling. Post 2006 is even better still because they added the aux input for the hifi. Try to get one with the Logic 7 audio as the stock hifi is complete junk.
If everything works, it has a FSH from BMW or a good specialist, and the price is right then they can be a good buy.
Get the engine checked out by a specialist before you buy. There is a bodge fix for the V8s for the water pipe that fails that some people do to move the car on. The only permanent fix is a complete engine strip and rebuild.
Have a call with the head tech from the NE today over my mystery noise. Dun dun dunnnn!
Sure you do. It's actually Mikey, the 16 year old apprentice on his way to find a left handed screwdriver.
That's the issue, I can't even pay for anything, all I can do at https://www.bmw-connecteddrive.co.uk is confirm the security code which has been sent to my car, but there's no code, there isn't even a messages section within ConnectedDrive.
