Like.
£85k brand new. £50k for a 12 month old example
in 12 months time yeah
My car came up with an oil level at minimum, topup when you can so as I was passing a dealer near Bracknell I popped in and asked if they could top it up as I had the service pack. Caused mucho confusion with a lot of toing and froing but obliged in the end.
Caught it due to the fluctuating very low idle revs and some strange noisesDid it fail spectacularly or did you catch it early?
Dilemma: Do I take the car all the way back to Birmingham to the garage who replaced my suspension and everything about a year ago, or do I take it to this garage a few miles away from where I am who I trust to do a good job.
BMW telling me my Inspection II is due in March and will probably also need to replace spark plugs (why/how can they know that?), but I thought they moved to condition based servicing 2011 E93.
It is condition based but on the E9x series it works like this:
Every two years or 16700 miles (+/- 3000 depending on how the car is driven, this is the CBS), whichever first occurs.
First service (at two years old or on mileage) is Oil, Oil Filter, Microfilters.
Second service (at four years old or on mileage) is Oil, Oil Filter, Microfilters, Spark Plugs (or Fuel Filter if diesel), Air Filter.
Thereafter it alternates between the minor and major scopes of work.
There is also a vehicle check inspection (icon is of the car up on ramps) which is due infrequently.
If you fiddle with the stalk button (or go into iDrive, if you have that) you will find a service menu that tells you what is due and when.
M3 are probably a bit different, shorter intervals and the run-in service at 1200 (cannot exceed 2000).
