Don't listen to him! The S55 IS a proper M engine in every way!
I have sports automatic in my 530d and I never use the paddles. Pointless.
I think without sports auto you don't get launch control. I'm not going to lie without it how will you impress the ladies?
As it is a 5 touring with a kid seat in the back, launch control will not be needed.....
So why a 535d at all? I found that the 530d is much better value and will allow you into a newer or better spec car for the money. And with 0-60 in 5.8 its hardly slow.
https://usedcars.bmw.co.uk/vehicle/201903015429255?location=London, UK"eref=0f045883-fff2-4d4c-8602-f4d76dc5fa2f
What do people think? I’m assuming it would have Hk sound as it is msport even though it’s not listed.
I’m not entirely worried of 535 or 530, but seems a good overal spec. I’ve given up looking for comfort seats or adaptive drive as both seem to be rare.
The issue with 20k plus F10/11s is the G30/31 is available under 30k.
Just a local example - it's not approved used and its an SE but:
https://www.autotrader.co.uk/classified/advert/201812083094170?postcode=le158lh&radius=40&onesearchad=Used&onesearchad=Nearly New&onesearchad=New&price-to=30000&sort=recommended&price-from=20000&make=BMW&advertising-location=at_cars&body-type=Estate&model=5 SERIES&page=1
Newer by 2 years, half the mileage.
I didn't realise the key records certain events. What does it record exactly, and what is it used for?
Have a 2018 X3. Does anyone know whether these keys deactivate the transmitter once planned down?
Other half keeps hitting the boot button, as a result, the boot was open all night last week! Luckily we had no rain.
I read somewhere that dealers can code it so it stops accidental boot openings, might be worth asking your dealer?
Have a check here https://x3.xbimmers.com/forums/forumdisplay.php?f=666I’m going to have to. Boot was open all night long. Just thankful that it didn’t rain, otherwise, would have been a much worse and possibly water damaged.
What setting do they apply? Someone mentioned you can disable the boot opening of the doors are locked.
That's great, thank you.Have a check here https://x3.xbimmers.com/forums/forumdisplay.php?f=666
I think there is a way to code it so you have to have the car unlocked, or press the boot button twice. I have my key in a loose coat pocket (although have comfort access, not sure if you do) so I've not sat on it or anything. When the summer comes and I've got the key in my jeans pocket this could become an issue though, so I'm thinking of looking into the same thing.
I wouldn't call them pointless? Manual gear shifting is much better when going for an enthusiastic drive out. I find the car holds to 5K which is a bit pointless, that and the gear coming out of corners isn't always right so it'll quickly jump down a gear when you put your foot down, I prefer to be in the right gear coming into the corner.
If 575bhp is your thing, personally I’d be looking at an M5 rather than an X5, they are epic for what they are (Brother in law had an X5 M550d which was bonkers) but the M5 just kills it in terms of a drivers car imo.
