And wait for the abuse
Don;t like the nostrils and dont like the wheels, they look too big IMO. happy now?
Other than the awful looking grille which has been covered about a million times it's a 2 door version of probably one of the best cars BMW have made for a while - the 3 series - so I bet it's brilliant.
However... Is that a 420i?! You've gone from an 840i to a... 420i?
Yes thanks
Its a 5 door rather than a 2 door and yes 420i. The 430i is 5K more expensive than the 420i and I was trying to reduce the cost as well as having something more practical.
Personally I would have dumped the wheels and paid more for the 430i. You would get more enjoyment from that, only other people look at the wheels. Plus the 430i is only £4k not £5k more expensive.
It was a pre-built car so I didn't get a choice on the spec, this one I got a good deal on, including the px of the 840i. It had enough kit on to not feel like a catastrophic downgrade from the 840i, and looked good, so went with it. I was also looking for something more practical and which would save me some cash as I'm doing a lot less mileage than before and the 840i is not a cheap car to buy let alone run.
I drove it home last night and whilst it's clearly not a 333 BHP straight 6 it's not a bad drive and the ride is more compliant than the 840i was. I can also get my kids easily in the back, rather than just about get them in the back, and its got an easily accessible boot, which when you have a wheelchair to get in is important.
£60 for wiper blades... £231 for a washer hose. Yeah, go elsewhere
Diff leak after quick google on E90s, people had them both replaced by BMW for £170, so getting shafted there100% on those two things, they're being jokers on the wiper blades - I just have no idea on the diff leak, rear axle pipe corrosion...
Shock absorbers you'll be able to get decent cheaper pattern parts
Bushes, the starting to perish probably could ignore but if having dampers replaced then could get the indy to replace at the same time
Brake hoses not entirely sure how much work that is myself... maybe someone else can advise...
Overall would recommend getting some quotes from independents, not worth BMW dealer prices for a 15 year old 3 series
£77 each for bonnet struts? Are they serious?
Are these prices include fitting as well, given their hourly rates it isn't really a big surprise at all. I don't know if some BMW owners wish to maintain their vehicles on a shoestring budget but genuine parts from a dealership are always more expensive. Yes cheaper versions can be purchased from the Internet, such as fleabay, but if they're not genuine then they will be of dubious quality...
