[TW]Fox;27149121 said:It's bizarre really but I really dont like the multifunction instrument panel. It just looks far too busy and blingy. The standard fit full black panel display you'll have on your new car looks so much more neat and professional.
[TW]Fox;27149151 said:Actually I revise that, I've just noticed you can have the multifunction display looking very much like the normal full black panel display. Most pictures people post have it in full on blingWTF mode
http://paultan.org/2012/05/14/new-enhanced-black-panel-for-bmw-f10-from-july-2012/
2nd one down appears to be normal mode, which looks great.
Question for anyone in the know.
When I had my car serviced last week they did a vehicle check. On it came up that my rear dampers and covers are perishing and a pulley was causing a squeak under the bonnet (something i asked them to check out).
The guy who i was dealing with said the dampers are not covered under the warranty but the pulley was.
The warranty states that "Any item that has worn out rather than suffered from a defect" is not covered. I have comprehensive cover.
Should dampers need replacing from general wear after 65k miles?
if they arnt covered how much would i be looking at?
Hi all,
The 330 needs new handbrake shoes which is easy enough. I know I need a new fitting kit with all the springs in, but will I also need any other bits? On the RealOEM website they list the value kit which comes with everything at approx £100 and includes new adjusters and locks:
http://realoem.com/bmw/showparts.do?mod ... g=34&fg=40
Do I need to replace those bits too or will I be okay with new shoes and the spring kit?
It's my first time messing around with handbrake shoes so not sure if those bits are necessary.
Thanks
I can't see your realoem link but are you questioning whether backing plates are needed?
If these are in decent nick (i.e the hole is still a normal sized and shaped hole) then all you should need are the springs and shoes. If it's the rest of the mechanism without the backing plates then personally I wouldn't bother unless again you know the adjsuter is goosed
If they're buggered then the right thing to do is replace them, but you can also repair with washers or bolts if you so wish!
My Dampers were not covered under warranty on my 330d, cost from BMW was £616 to replace
