What if Wingman has puny arms?
At least I don't need to work out to fill out my leather jacket
The M44 that is currently in the car is only 140bhp
the M52 is 192bhp ... its pretty much a straight swap.
Engine
Loom
ECU
gearbox
Rear diff
all just straight swap parts.
not sure how its not compatible with the car when the m52 comes in every E36 328 sport?
If S52 m3 engines where not 2k + id do that swap..
but for around £600 its well worth the swap to the M52
[TW]Fox;27349671 said:It usually is, yes, but any loss of coolant is a cause for concern - you have a leak or some other fault thats caused it. It doesn't naturally vanish.
When I was loosing coolant on my old E46, as I couldn't find a leak, I just chucked some "Radweld" in and it fixed it nicely
