Should a 2010 F10 with professional navigation be able to stream music via bluetooth? It has a USB and aux socket in the arm rest and another USB in the glovebox but couldn't stream?
Production date: 09.08.2010
noooooooooooooooooooooooooooooooooooooo
Can it be added with a firmware update?
Had an 'overheating' error appear yesterday after about 30 minutes driving and then a few minutes later 'overheated'. (Oil temp was fine).
Turned out to be a coolant airlock.
Vid/Snip
I could have sworn I read BMW's used sealed/closed coolant circuits, sparking some debate, so checking water levels was never on the 'to do' list. Emergency Service came out within half an hour and had it cleared shortly after.
Just curious how an airlock can develop? I've not opened the water cap since owning the vehicle (over a year) so unless when it had an oil service and MOT two weeks ago they've topped it up and trapped some air in there? Quite a bit came out...
The water pump is working fine and was continuously pumping once the air was cleared. My local Indy thinks it could be the thermostat.
Has anyone had this before or something similar?
I'd keep an eye on this. I don't think it is the airlock. When my water pump needing replacing it would suddenly after about 10 miles of driving go from a steady 90c, to then feeling the air from the vents suddenly going cold and water temp steadily going up to around 120c followed by it then saying it was overheating. All I had to do was stop the engine and restart it and the temperature would suddenly fall back down to 90c and I'd be fine for the remainder of my journey, however long it was.
It's almost like the water pump would just suddenly stop, then when the engine had been restarted it would kick back to life and work fine again. Strange symptoms but fixed with a new water pump, which are common items to fail.
Yep, just checked my coolant on my lunch despite refilling it this morning and it's dropped.
Turned it over and could see the pump working with the cap off but the radiator fan kicked in almost immediately :/
Edit: A bit of googling as also revealed I might have some contamination/carbon build up on the valves as I get some lumpy power delivery when pulling away semi-regularly and have noticed decreased economy recently too. Anyone experience similar with the N55?
So, car has gone into today for its replacement bootlid. Got a lovely Citroen DS3 1.4 diesel courtesy car.
Probed them a little about how the work would be done and turns out they wont be blending the bootlid into the wings. Not sure if this is due to the fact its being done on the corrosion warranty or not, but guess we'll see how it turns out.
The other interesting bit was that they stated the E92 M3 lip spoiler is no longer available from BMW (i.e not manufactured), so I guess we'll see if they can get mine off without damaging it.
How many keys should an F10 come with?
I managed to get my fan off pretty easily with a whopping big spanner and a screwdriver - you can get the tool which would make life a bit easier, but it can be done without
I swapped my belts with Contitech ones from ECP, did the trick and haven't had a single squeel since they were done.
Going to change the waterpump and auxilliary belts on my car (330d auto). It looks fairly straightforward apart from the fan removal which requires a specific tool.
Is this an E46 330i?Car pulls much better lower down, you can feel the extra torque which I wanted. Higher up the Rev range it just keeps pulling and pulling. Where as before it seemed to bog down after 5k revs.
