A friend of mine in the motor trade has had a M135 come in and said he can do me a good deal on it
I'd never considered one before but it does look like a nice car, it is a 62 plate with 30k on the clock
I'm going to go down and take a look at it I think to see if it is something I fancy, are there any particular options that came on these cars that I should be looking for? I know that you seem to get quite a wide choice with BMWs
All I know at this stage is that it is auto with leather
what is "essential" is different for everyone, for me the basics were...
rear park sensors [if its got fronts as well even better as the beep doesn't turn off when you take it out of gear with rear sensors only dealer should have made this clear IMO]
lumbar support
adaptive front lights with high beam assist
full black panel display
tinted glass
the wants but couldn't justify cost were ....
Pronav [can be retrofitted easily for under £700 now so its up to you]
electric seats [can't get folding mirrors without this option IIRC]
heated seats
Auto
and the waste of time for me was
adaptive suspension
full comfort access
sunroof
lane assist
extended Bluetooth
lots of other options but those are the ones that have stuck in my mind
make sure there is plenty of rubber on all tyres, ideally Michelin Pilot Super Sports, they come with about 7-8mm new but once they drop below 4-5mm the performance drop is noticeable, runcraps became an option on later cars so you should be fine
outer edges of front tyres take a beating as the compound is supposedly different, I cant say for sure but wear in this area is common
no major issues to report on the cars other than a bit of excessive creaking and rattling on the plastics that I am aware of on the couple of forums I visit, there was a brief period early on with people citing buckled alloys but not heard anything recent about it
if you go for a test drive make sure its fully warmed up and stick it in sport mode to appreciate the throttle response, sport plus if you want a looser back end and are used to RWD
