[TW]Fox;29156538 said:Can't stand it, it's not black its just really dark navy blue.
My Dad has a 520d, it's never fast but never slow either if that makes sense. It's all the performance you'd ever need, just not necessarily all you'd ever want.
[TW]Fox;29156736 said:On a 520d don't forget that the standard specification misses the proper climate control, so it may be worth individually optioning that.
Otherwise the specificaiton is now so good that beyond M Sport Plus (Which itself is a personal taste thing rather than a must have) and Professional Media Package there are no longer any essential options - when the F10 first came out there was quite a list of essential options.
Personally I'd spec Park Assist and Reversing Camera which for about 600 quid give you self-park and a camera. There are a few little bits like that, really cool options that don't cost much.
I love Carbon Black on mine
When you say 'proper' climate control, what's the difference between that and whatever is fitted as standard? Is it just air con?
Sports auto is a good shout too, isn't it something like £160 more than the normal auto?
[TW]Fox;29158424 said:It's climate control, but it lacks features like a sun load sensor, fogging sensor, variable auto vent speed programmes, different vent speeds for driver and passenger etc.
Not available on the 520d since the LCI, only available on the good ones
To be honest with so many used ones being around with the M Sport Plus package buying a brand new 520d strikes me as totally daft.
If you've got £35k to spend you can buy something better than a 520d. If you don't want something better than a 520d you can save 10 grand and buy a 520d.
The Goodyear excellence on mine are lasting well. Fronts have done 38k. Rears would have too had it not been for a poor alignment issue.
Thanks for the tyre input. I've got Goodyear EfficientGrip Performance all round as they're A rated for wet and I like having grip in the wet as it's the first rwd car i've owned!, and they're B-rated for fuel (which helps when you do 500 a week)
I just don't want to be spending more than £500 a year for 4 tyres - although the rears will obviously wear quicker than the fronts, and I'll prob go 14+months on the fronts.
A friend of mine with an A8 swears by using winters all year round, but I guess his 4wd system means the tyres wear much more evenly.
