[TW]Fox;29310975 said:Exactly the same problem my Dad had with his 2007 525i in 2010.
BMW ended up replacing he ECU and all 6 injectors and it worked after that.
The N53's direct injection system is a massive nuisance.
BMW ownership update rybo
It's heavily dependant on your journey length. It sort of has the opposite efficiency curve to a normal car, in that shorter the journey the better. Tbh I expected less than this, was hoping (and budgeted for) 60-70mpg so very happy.
I drove for 14 miles around Bristol centre last night and achieved even higher MPG. Unfortunately the in-car display is capped at 99.9 (what a stupid design choice this was!) and I only realised this morning with the phone plugged in and app running you could get more info from the 'Eco Pro Analyser'.
Well for reference I get 35mpg in a 520d mostly in normal Bristol traffic. Those figures are impressive.
A guy in work has just got an i8. I haven't checked what his MPG is but I imagine it is not too shabby. Not that he cares considering the purchase price lol
[TW]Fox;29311832 said:There is a massive difference in concept between the two though - the 330e can drive around town with the engine off.
It sounds absolutely excellent. It's a shame the 530e won't be around until the next generation 5 Series.
According to sources, the BMW 540e will be equipped with a gasoline engine four-cylinder TwinPower turbo producing 258 hp and 400 Nm of torque featuring a VALVETRONIC valve control, control double overhead camshaft VANOS and “High Precision Injection” direct injection, together with an electric motor of 95 hp for a total power of 326 hp.
The peak power of the electric motors and combustion engine are not delivered at the same time.Sign me up for that one... If true. Was thinking of ditching the current 5 series around November, when it is 3 years old. Might just get a cheap "stop-gap" until a 540e is released, should such a thing ever exist.
Of course, maybe my maths doesn't work because I always thought 258+95=353...
Anyone know if a 3 Series Touring has more rear legroom than the standard car or is it just more boot space?
So cylinder 3 and 6 have had a new injector,plug and coilpack and the new injectors coded. (all had new NGK plugs)
3 and 6 are still misfiring on start up. This is reading the cylinder smoothness values on a proper machine. Both Cylinder 3 and 6 go into the + values (up to +6.xxx) which is when the car gets a big missfire.
I have 4 more new injectors here but this has put a bigger spanner in the works with 3 and 6 still acting up, so i am not wanting to put the other 4 in now incase the problem still persists meaning ive chucked money at it for bugger all.
Anyone got any ideas? Maybe electrical? Someone mentioned a BMW update as the ECU controls the start up procedure.
The internet is literally littered in threads about the same symptoms as mine. After the car sitting for 8+ hours and then starting it the car will vibrate for 2 min with a loss of power if driven, then after that 2 minutes the car runs 100% perfect, not even the slightest of misfires. Leaky injectors would make perfect sense and the solution to most of these problems is new injectors. Just doesn't make sense that my 3 and 6 are still the only ones misfiring on a cold start even if i haven't replaced 1,2,4 and 5 aswell.
Fancied seeing if anyone on here has any ideas before i book it into BMW. Which i reckon will just say plugs/coils/injectors.
Stormster, you know when i said i haven't had any Big bills yet, well thats gunna change lol, ****in thing.
