I have a separate vacuum cleaner for each element of my life I care about, one for my car and erm that's it
It's not just about grit though is it. It's the notion of using the same brush you've used on carpets that have had shoes rubbing against them for months/years that have been exposed to many unhygienic surfaces.
Honestly
I have never had to use a vacuum brush on my seats in all the years I've owned a car. Look at the condition of my seats on every car.
The amount of grit in the floor mats is massive, even when appearing to be clean. Rubbing this grit over leather seats isn't a great idea if you want them to not go shiny.
I doubt it makes any difference if you go lightly or the brush doesn't retain grit. I mostly use a damp cloth to clean my seats and only use a Hoover nozzle if there is lots of grit in the crack.
It looks as though the leather has just been wet wiped!
PS4's or F1-AS3's.
I'm going to have a look at this tomorrow: http://www.autotrader.co.uk/classified/advert/201608046496359
Looks pretty clean to me considering the car has done 100k miles and it has full service history.
What do you guys think of the mileage and 3 litre diesel engine?
EDIT: Forgot to mention that if I was to buy this, the colour of the wheels will be back to silver.
Everyone just wanna be me, dont they....
My car is actually for sale/ish though. But that is not mine, tractor engine and auto.
