**Borderlands Pre Sequel** SHIFT keys in first post!
I would just clarify, it has a pretty high chance to spit out a single higher rarity level item, but frequently it's not actually a better item. I've had so many times that three blue pistols, often good ones, end up being a useless purple. It could just be very bad luck but I would say purples from the grinder have a high rate of being less wanted types. I've only got useless SMG's out(non elemental and not particularly high damage) and pistols, I've gotten one decent purple pistol, but loads of low mag size, low fire rate explosive or non elemental pistols that really. Almost none of my purples from the grinder have ended up better than other guns I've had. It's basically just another jackpot machine, you need to just keep doing it over and over and eventually will get something worthwhile. It is pretty epic trolling worthy to actually name the machine a grinder though :p
My advice is, if you have a great gun, stick with it, grind others and if the result is better than what you have(not in stats, but actually using it), then grind the old gun. Two of my best guns right now are two green beam lasers, I have purple(from grinding) lasers of pretty much every type and element yet none of them offer the damage output or usability of the green beam ones.
If you have a good beam laser with a +150% continuous fire damage bonus.... you're laughing.
As far as i can remember every weapon i've created has been better than any of the ones i put in. Though i've mainly put in white guns or green with moonstone.
Regardless of which, i'm struggling to see the point of the grinder at the moment. Maybe someone will document the best ingredients by the end of the year to make it useful in late TVHM and UVHM.
150% continuous damage lasers are my favourite at the moment, got a few great ones. Even better with Wilhelm's laser damage increase skill :D
Codes are appearing near enough everyday so may as well spend them, at the top levels you're going to be wanting legendaries anyway.
I think the first post needs editing.
The first set (column) of keys are for the PC the next are PS3 and the last are Xbox
To show the different keys for different machines or just delete the PS3 and Xbox ones.
meh, another luneshine from a box, rocket launcher... meh. 3% shield increase, base shield amount as well. For such small bonuses it would be at least nice if you could have 4 active at a time from the weapon slots not just the equipped one so they stacked 3% seems almost worthless. Actually does anyone know if you can get luneshine bonuses on other equipment, nades, o2 mask, shield? I've seen a half dozen on weapons and none on anything else yet.
Hmm I thought I only included the PC ones. I will edit it tonight when I get home.
I'm stuck at Regolith Range. There is a door that I can't open. It's basically the first one towards the left which you have to use the boost jump. I got it through it before with MissChief but when I try to go through by myself, it keeps saying All Players Must Be Present. Can I not solo this part of the map?
Edit: nevermind, the door literally opened when i exited the bubble and re-entered. Why it couldn;t open the first time is beyond me.
Happened to me too and fixed itself by running in and out. Seems to be a common bug.
For anyone using Wilhelm, you can get the 'Who Needs Air?' achievement by just using his ability a few times when out of air.
I redeemed all these a few days back, some dating to 2013:
KTCJJ-FHZJW-W6JJB-TTBTJ-R9WWJ
WTCJ3-SHH3K-KFJT3-JBJ3J-H5965
CTWTB-JTBW5-KFTTT-JTB33-JTBWB
5T5B3-CWJSK-KRTJT-TTJJT-9HW63
KJ5BT-FBKSK-KXJ3T-3BTJT-FJX5C
WT5TB-XC5ZC-CX3T3-BBT3B-B35WB
WTCBB-H5WHC-5F3T3-TBT3T-HR6TJ
5BKBB-TXWS5-WX3BB-TBT33-3SHSB
K3K33-3W9JT-6XJJT-TB3JB-HWZZF
WTC3B-Z5ZWC-HW6JT-JJJBJ-9FWXR
W3WJ3-3JXTT-6RW5T-SB53B-XJBX9
KBWJJ-WTXB9-C59J6-WFBTJ-TK6BJ
K3WJT-BFBRW-S5RTT-TBBB3-9XWZ5
KBC3J-95WXF-WBSBT-TTJJB-KTC6K
KB53J-RW5XX-539BT-BJT3J-CC55T
WB5TT-JFCXX-CBS33-TTTBJ-JJ95B
CTC3J-KR9H5-WTZ3T-TJ3TB-6SRRJ
WB53J-KRRXW-5KXCB-STKTT-XC5BR
KJWB3-6RXRC-CKR5B-H3WB3-WZRF5
CJCJ3-B6XXC-CK6WT-HTWTB-5SSW5
KJKJ3-T396C-RS93J-TJ3BJ-5W3S6
WJCBB-SSFFC-XH93J-BJTBT-Z66ZW
5TKJJ-5THRC-XZZ3J-33J33-TSZSC
WBCTT-XX3RK-HK6TB-TTTTT-B5Z53
C3KJ3-WCZW3-H5TFK-BTB3T-9RKTZ
CB5T3-TCZKT-Z5TX5-33JB3-BWCCT
53KBB-63J9B-HCJR5-3TTJJ-SXJFW
53KJT-6RBZ3-9WJRC-33T3T-FRKFS
KB53T-CRTHT-ZC3RC-3TBB3-3BRWB
Unless they're special codes, they won't expire.
