The small numbers "310/35" you see imprinted at the base of the CISA lock are key identification numbers.
Get a pin and try to dislodge the broken key without pushing it further into the barrel. Then get some very fine needle nose pliers and pull it out.
Then you can contact the manufacturer for a 310/35 key and provide them will all the details of ownership, they should send you a key in a few days.
Pliers, pull key out, use correct key. Not a problem.
Trying to grab the broken key with a piece of metal and superglue sounds like a good shout, but if it goes wrong, you'll jsut end up with a lock barrel full of superglue instead.
why do you hold suerglue in such high regard, it's great for sticking plastics and fingers - not metal.
Just cut the thing that goes into the lock, it's really thin at the edges where that second hole is through it further up. It'll be weaker than the lock
Take lock picking lessons, they will come in handy again eventually
Good point. You could get through that with a hack saw or angle grinder.Just cut the thing that goes into the lock, it's really thin at the edges where that second hole is through it further up. It'll be weaker than the lock
